Datasheet Texas Instruments SN74LS42DG4 — Даташит
СерияSN74LS42
МодельSN74LS42DG4
Десятичные декодеры с 4 строками BCD на 10 строк 16-SOIC от 0 до 70
4-Line BCD To 10-Line Decimal Decoders datasheet
PDF, 218 Кб, Файл опубликован: 1 мар 1988
Микросхема Логический контроллер, Decoder/Demultiplexer Single 4-to-10 16Pin SOIC Tube
SN74LS42DG4
110 ₽
SN74LS42DG4
144 ₽
SN74LS42DG4
LifeElectronics
SN74LS42DG4
Pin16
Package TypeD
Package QTY40
МаркировкаLS42
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Полоса частот35 МГц
Bits10
Количество каналов1
Configuration4:10
Digital input leakage(Max)5 uA
ESD Charged Device Model0.75 kV
ESD HBM2 kV
F @ Nom Voltage(Max)35 Mhz
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)13 мА
Output Drive (IOL/IOH)(Max)8/-0.4 мА
Schmitt TriggerNo
Technology FamilyLS
ТипStandard
VCC(Max)5.25 В
VCC(Min)4.75 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)30 нс
  • Hardware Design Considerations for a Wireless LED based Display Design
    PDF, 682 Кб, Файл опубликован: 11 июн 2014
    Scoreboards have different purposes with various features. Scoreboards are typically used for displaying scores of a game played between two teams. These games can be a timed or an untimed event. The application described in this application report creates a multi-sport scoreboard that is cost efficient, portable, and easy to use. The display values on the scoreboard are transmitted wirelessly.
  • Designing with the SN54/74LS123 (Rev. A)
    PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN74LS42 (4)
  • Semiconductors > Switches and Multiplexers > Buffered Encoders and Decoders
На английском языке: Datasheet Texas Instruments SN74LS42DG4
