Datasheet Texas Instruments OPA129UB — Даташит
СерияOPA129
МодельOPA129UB
Операционный усилитель Difet со сверхнизким током смещения 8-SOIC от -40 до 125
Ultra-Low Bias Current DifetВ® Operational Amplifier datasheet
PDF, 587 Кб, Версия: A, Файл опубликован: 28 апр 2007
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY757575
CarrierTUBETUBETUBE
МаркировкаOPA129UB
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)80 дБ
CMRR(Typ)118 дБ
GBW(Typ)1 МГц
Input Bias Current(Max)0.1 pA
Iq per channel(Max)1.8 мА
Iq per channel(Typ)1.2 мА
Количество каналов1
Offset Drift(Typ)3 uV/C
Output Current(Typ)35 мА
Rail-to-RailNo
Slew Rate(Typ)2.5 V/us
Total Supply Voltage(Min)10 +5V=5, +/-5V=10
Vn at 1kHz(Typ)17 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Designing Photodiode Amplifier Circuits with OPA128
    The OPA128 ultra-low bias current operational amplifier achieves its 75fA maximum bias current without compromise. Using standard design techniques, serious performance trade-offs were required which sacrificed overall amplifier performance in order to reach femtoamp (fA = 10-15A) bias currents.
  • Diode-Connected FET Protects Op Amps
    PDF, 49 Кб, Файл опубликован: 2 окт 2000
    Providing input-overload protection for sensitive measurement circuits proves difficult when you must not degrade the circuits? performance in the process. It?s an especially tricky problem when you?re measuring a material?s dielectric properties. In such an application, an ultra-low input bias current op amp serves as a current integrator to measure a dielectric?s response to a 100V step.
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA129UB
