Datasheet Texas Instruments OPA2613IDTJ — Даташит
СерияOPA2613
МодельOPA2613IDTJ
Двойной широкополосный операционный усилитель с высоким выходным током и ограничением тока 8-HSOP от -40 до 85
Dual, Wideband, High Output Current, Operational Amplifier with Current Limit datasheet
PDF, 709 Кб, Версия: H, Файл опубликован: 28 авг 2008
Зенер
Россия и страны ТС
OPA2613IDTJ
от 454 ₽
OPA2613IDTJ
OPA2613IDTJ
OPA2613IDTJ
Package TypeDTJ
Industry STD TermHSOIC
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.39
Max Height (мм)1.75
Рекомендуемая замена
ReplacementOPA2613ID
Replacement CodeQ
2nd Harmonic(dBc)70
3rd Harmonic(dBc)84
@ MHz1
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)1.70 | 1ku
АрхитектураBipolar
Voltage FB
BW @ Acl(MHz)230
CMRR(Min)(dB)88
CMRR(Typ)(dB)100
GBW(Typ)(MHz)230
Input Bias Current(Max)(pA)12000
Iq per channel(Max)(mA)6.2
Iq per channel(Typ)(mA)6
Number of Channels(#)2
Offset Drift(Typ)(uV/C)3.3
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)350
Package Size: mm2:W x L (PKG)8SOIC: 29 mm2: 6 x 4.9(SOIC)
Rail-to-RailNo
Slew Rate(Typ)(V/us)60
Total Supply Voltage(Max)(+5V=5, +/-5V=10)12
Total Supply Voltage(Min)(+5V=5, +/-5V=10)5
Vn at Flatband(Typ)(nV/rtHz)1.8
Vos (Offset Voltage @ 25C)(Max)(mV)1
RoHSНе совместим
  • Evaluation Modules & Boards: DEM-OPA-SO-2A
    DEM-OPA-SO-2A
  • Evaluation Modules & Boards: DEM-OPA268XU
    DEM-OPA268xU: Demonstration Fixture
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
  • Tuning in Amplifiers
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA2613IDTJ
