Datasheet Texas Instruments TPS54680PWPR — Даташит
СерияTPS54680
МодельTPS54680PWPR
3V to 6V Input, 6A Synchronous Step-Down SWIFT™ Converter for SequencingВ  28-HTSSOP -40 to 85
3-V to 6-V Input 6-A Output Tracking Synchronous Buck PWM Switcher datasheet
PDF, 811 Кб, Версия: B, Файл опубликован: 26 окт 2005
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPS54680
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
  • Evaluation Modules & Boards: TPS54680EVM
    6-A DC/DC Converter with Simultaneous Sequencing of Multiple Voltages
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Using TPS54x80 Tracking SWIFT(TM) dc/dc Converters f/Simult. Tkg of Input Supply
    PDF, 115 Кб, Файл опубликован: 10 фев 2005
    High-performance signal processing devices, such as FPGAs and DSPs, require multiple power supply voltages for operation. The order and timing in which these supply outputs power up and down is usually specified. A design example using the TPS54380 is shown for the case where the power supply to be tracked is also the input voltage to the TPS54380. Information is provided for adjusting the start-u
  • Designing for Small-Size, High-Freq Applications Using TPS546xx DC/DC Converters
    PDF, 646 Кб, Файл опубликован: 19 окт 2001
    This application report describes the design procedure for a small-size, high frequency application using SWIFTВ™ synchronous buck regulators. It shows that the compensation circuitry of the regulators, with the minimum size output filter and fast transient response, provides the 150-kHz unity gain bandwidth of the open feedback loop. The design is illustrated by the 6-A, DDR memory VTT track
  • Sequencing with TPS54x80 and TPS54x73 DC/DC Converters
    PDF, 169 Кб, Файл опубликован: 14 апр 2003
    Design of a power supply for a high-performance point-of-load processor requires special attention to manage core and input/output (I/O) voltage sequencing, which is critical to device operation and long term reliability. The TPS54x80 devices of low input voltage synchronous-buck dc/dc converters are designed for easily implementing sequential, ratio-metric, or simultaneous sequencing schemes. F
  • Simultaneous power-down sequencing with the TPS74x01 family of linear regulators
    PDF, 312 Кб, Файл опубликован: 10 авг 2007
  • Optimizing the Layout of the TPS546xx for Thermal Performance (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 8 фев 2002
    This application report examines the thermal performance of different layout techniques for the TPS5461x family of 6-amp synchronous buck regulators. The TPS5461x family consists of the TPS54610, TPS54611, TPS54612, TPS54613, TPS54615, and the TPS54616. The TPS54610 has an adjustable output voltage, while the output voltages of the other devices in this family are fixed. This application note is a
  • Q3 2007 Issue Analog Applications Journal
    PDF, 617 Кб, Файл опубликован: 10 авг 2007
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54680 (4)
На английском языке: Datasheet Texas Instruments TPS54680PWPR
