Datasheet Texas Instruments 74CBTLV16211CGRDR — Даташит
СерияSN74CBTLV16211C
Модель74CBTLV16211CGRDR
Низковольтный 24-битный коммутатор шины на полевых транзисторах 54-BGA MICROSTAR JUNIOR от -40 до 85
SN74CBTLV16211C datasheet
PDF, 425 Кб, Файл опубликован: 5 июл 2005
АЦП азиатских производителей
Pin54
Package TypeGRD
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаCN211
Width (мм)5.5
Length (мм)8
Thickness (мм).8
Pitch (мм).8
Max Height (мм)1.2
Additional FeaturesPowered off protection
Полоса частот200 МГц
Configuration1:1 SPST
ESD HBM2 kV
Input/Ouput Voltage(Max)3.6 В
Input/Output Continuous Current(Max)128 мА
Input/Output OFF-state Capacitance(Typ)6.5 пФ
Количество каналов24
OFF-state leakage current(Max)1 мкА
ON-state leakage current(Max)1 мкА
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L54BGA MICROSTAR JUNIOR: 44 mm2: 5.5 x 8(BGA MICROSTAR JUNIOR) PKG
Ron(Max)40 Ohms
Ron(Typ)5 Ohms
Supply Current(Max)10 uA
Supply Range3.6 Max
VIH(Min)2 В
VIL(Max)0.8 В
Vdd(Max)3.6 В
Vdd(Min)2.3 В
Vss(Max)N/A В
Vss(Min)N/A В
RoHSSee ti.com
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: SN74CBTLV16211C (2)
На английском языке: Datasheet Texas Instruments 74CBTLV16211CGRDR
