Datasheet Texas Instruments SN74LVCH16244AGRDR — Даташит
СерияSN74LVCH16244A
МодельSN74LVCH16244AGRDR
16-битный буфер/драйвер с выходами с 3 состояниями 54 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVCH16244A 16-Bit Buffer/Driver With 3-State Outputs datasheet
PDF, 866 Кб, Версия: B, Файл опубликован: 7 ноя 2013
Pin54
Package TypeGRD
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Width (мм)5.5
Length (мм)8
Thickness (мм).8
Pitch (мм).8
Max Height (мм)1.2
Рекомендуемая замена
ReplacementSN74LVCH16244AZRDR
Replacement CodeP
Approx. Price (US$)0.45 | 1ku
Bits(#)16
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.02
Тип входаTTL/CMOS
Operating Temperature Range(C)-40 to 125
-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаLVTTL
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L (PKG)54BGA MICROSTAR JUNIOR: 44 mm2: 5.5 x 8(BGA MICROSTAR JUNIOR)
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)6.6
3.9
4.7
4.1
RoHSНе совместим
  • Simultaneous-Switching Performance of TI Logic Devices (Rev. B)
    PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
    Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
На английском языке: Datasheet Texas Instruments SN74LVCH16244AGRDR
