Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UCC28810DRG4 — Даташит
СерияUCC28810
МодельUCC28810DRG4
Контроллер мощности светодиодного освещения 8-SOIC от -40 до 105
LED Lighting Power Controller datasheet
PDF, 1.5 Мб, Файл опубликован: 22 окт 2008
Package TypeD
Package QTY2500
Маркировка28810D
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Dimming MethodAnalog
Входное напряжениеAC/DC Type
Iout(Max)5 A
Iq(Typ)4 мА
Power Factor CorrectionActive Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Soft Start,Soft Switching
Switching Frequency(Max)250 kHz
Switching Frequency(Min)5 kHz
TopologyBoost,Buck,Flyback,PFC Controller,Sepic
ТипInductive
Vin(Max)18 В
Vin(Min)13 В
Vout(Max)400 В
Vout(Min)9 В
Vref2.5 В
  • Evaluation Modules & Boards: UCC28810EVM-002
    A 0.9-A Constant Current Supply with PFC for 100-W LED Evaluation Module
  • Evaluation Modules & Boards: UCC28810EVM-003
    110-W Multiple String LED Driver with Universal Line Input and PFC Evaluation Module
  • Isolated 70-W Streetlight LED Driver Using UCC28810
    PDF, 1.9 Мб, Файл опубликован: 14 авг 2015
  • Speed-Control Techniques in AC-DC Operated BLDC Applications
    PDF, 165 Кб, Файл опубликован: 11 авг 2016
    To achieve energy efficiency, ceiling fans and ventilation fans are moving from simple alternate-current (AC) induction motors to brushless direct-current (DC) motors (BLDC). An AC-operated BLDC motor requires two sections to run the BLDC motor: the AC-DC power conversion section and the DC to 3-phase AC conversion section. The Texas Instruments reference design, TIDA-00652, helps to meet these ch
Серия: UCC28810 (4)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments UCC28810DRG4
