Datasheet Texas Instruments SN74LVC1G19DCKRG4 — Даташит
| Серия | SN74LVC1G19 |
| Модель | SN74LVC1G19DCKRG4 |
Декодер/демультиплексор 1 из 2 6-SC70 от -40 до 85
SN74LVC1G19 1-of-2 Decoder and Demultiplexer datasheet
PDF, 1.3 Мб, Версия: G, Файл опубликован: 31 авг 2015
Купить SN74LVC1G19DCKRG4 на РадиоЛоцман.Цены — от 5.88 до 77 ₽18 предложений от 15 поставщиков IC 1OF2 DECODE/DEMUX SC70-6. Decoder/Demultiplexer 1 x 1:2 SC-70-6. Logic - Signal Switches, Multiplexers, Decoders | |||
| SN74LVC1G19DCKRG4 Texas Instruments | 7.10 ₽ | ||
| SN74LVC1G19DCKRG4 Texas Instruments | 8.05 ₽ | ||
| SN74LVC1G19DCKRG4 Texas Instruments | 10 ₽ | ||
| SN74LVC1G19DCKRG4 Texas Instruments | по запросу | ||
| Pin | 6 | 6 | 6 | 6 |
| Package Type | DCK | DCK | DCK | DCK |
| Industry STD Term | SOT-SC70 | SOT-SC70 | SOT-SC70 | SOT-SC70 |
| JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
| Package QTY | 3000 | 3000 | 3000 | 3000 |
| Carrier | LARGE T&R | LARGE T&R | LARGE T&R | LARGE T&R |
| Маркировка | CYK | CYR | CYF | CY5 |
| Width (мм) | 1.25 | 1.25 | 1.25 | 1.25 |
| Length (мм) | 2 | 2 | 2 | 2 |
| Thickness (мм) | .9 | .9 | .9 | .9 |
| Pitch (мм) | .65 | .65 | .65 | .65 |
| Max Height (мм) | 1.1 | 1.1 | 1.1 | 1.1 |
| Mechanical Data | Скачать | Скачать | Скачать | Скачать |
| 3-State Output | No |
| Bits | 1 |
| F @ Nom Voltage(Max) | 150 Mhz |
| Gate Type | DECODER/DEMUX |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Logic | True |
| Output Drive (IOL/IOH)(Max) | 32/-32 мА |
| Package Group | SC70 |
| Package Size: mm2:W x L | 6SC70: 4 mm2: 2.1 x 2(SC70) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Special Features | Ioff,down translation to Vcc,low power |
| Sub-Family | Decoder/Encoder/Multiplexer |
| Technology Family | LVC |
| VCC(Max) | 5.5 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,3.3,5 В |
| tpd @ Nom Voltage(Max) | 16.1,6.5,5.2,3.9 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G19 (11)
- Semiconductors > Logic > Little Logic
