Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS62354YZGR — Даташит
СерияTPS62354
МодельTPS62354YZGR
Понижающий преобразователь 1 А, 3 МГц с I2C для динамического масштабирования напряжения 12-DSBGA от -40 до 85
800-mA 3-MHz Synchronous Step-Down Converter With I2C(TM) Compatible Interface datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 15 апр 2008
Pin12
Package TypeYZG
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
МаркировкаTPS62354
Thickness (мм).375
Pitch (мм).5
Max Height (мм).625
Control ModeVoltage Mode
Duty Cycle(Max)80 %
Iout(Max)0.8 A
Iq(Typ)0.028 мА
Package GroupDSBGA
Regulated Outputs1
Special FeaturesDynamic Voltage Scaling,Enable,Frequency Synchronization,Light Load Efficiency,Output Discharge,Synchronous Rectification
Switching Frequency(Max)3350 kHz
Switching Frequency(Min)2650 kHz
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)1.5375 В
Vout(Min)0.75 В
  • Using The TPS6235x Without The I2C Interface
    PDF, 69 Кб, Файл опубликован: 17 май 2007
    The TPS6235x series of DC/DC converters have an I2C-compatible interface that facilitates changing the output voltage for dynamic voltage-scaling applications. However, it is possible to use the TPS6235x series of converters, without the I2C interface, as a standalone DC/DC converter that can be dynamically switched between two fixed voltages. This technique does not work for the TPS62351.
  • Powering OMAP3 With TPS6235x: Design-In Guide
    PDF, 296 Кб, Файл опубликован: 3 дек 2008
    The OMAP35xx Applications Processors have a diverse set of power management features which potentially enable lower cost power solutions based on your application. This design-in guide describes a power solution based on the TPS6235x device. This guide can be used to evaluate this solution for your design or help you make decisions when designing in this solution.
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
Серия: TPS62354 (2)
На английском языке: Datasheet Texas Instruments TPS62354YZGR
