Datasheet Texas Instruments CD74HC4053NSR — Даташит
СерияCD74HC4053
МодельCD74HC4053NSR
Высокоскоростные тройные 2-канальные аналоговые мультиплексоры/демультиплексоры КМОП 16-SO от -55 до 125
CDx4HC405x, CDx4HCT405x High-Speed CMOS Logic Analog Multiplexers and Demultiplexers datasheet
PDF, 1.5 Мб, Версия: L, Файл опубликован: 6 фев 2017
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаHC4053M
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Bandwidth(Max)200 МГц
Основные особенностиLow Power,Low Crosstalk,Break-before-make
Package GroupSO
Package Size: mm2:W x L16SO: 80 mm2: 7.8 x 10.2(SO) PKG
Ron(Max)130 Ohms
Ron(Typ)45 Ohms
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
  • Evaluation Modules & Boards: LEADED-ADAPTER1
    Surface Mount to DIP Header Adapter for Quick Testing of TI's 5;8;10;16; and 24 pin Leaded Packages
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Live Insertion
  • Semiconductors > Space & High Reliability > Logic Products > Switches and Multiplexer > Multiplexers/Demultiplexers (Mux/Demux)
На английском языке: Datasheet Texas Instruments CD74HC4053NSR
