Оптопары и оптореле Megawin
Datasheet Texas Instruments LM340T-15/NOPB — Даташит
СерияLM340
МодельLM340T-15/NOPB
1,5 А, линейный регулятор с фиксированным выходом 3-TO-220 от 0 до 125
LM340, LM340A and LM7805 Family Wide VIN 1.5-A Fixed Voltage Regulators datasheet
PDF, 3.7 Мб, Версия: L, Файл опубликован: 29 сен 2016
Pin3
Package TypeNDE
Industry STD TermTO-220
JEDEC CodeR-MSFM-P
Package QTY45
Width (мм)10.16
Length (мм)14.986
Thickness (мм)4.572
Pitch (мм)2.54
Max Height (мм)4.7
Точность2.5 %
Основные особенностиN/A
Fixed Output Options5,12,15 В
Iout(Max)1.5 A
Iq(Typ)8 мА
Noise40 uVrms
Рабочий диапазон температурот 0 до 125 C
Output Capacitor TypeCap Free,Ceramic
Output OptionsFixed Output
PSRR @ 100KHz50 дБ
Package GroupTO-220
Package Size: mm2:W x LSee datasheet (TO-220) PKG
Regulated Outputs1
Thermal Resistance ОёJA24 В°C/W
Vdo(Typ)2000 мВ
Vin(Max)35 В
Vin(Min)7.5 В
Vout(Max)15 В
Vout(Min)5 В
  • AN-256 Circuitry for Inexpensive Relative Humidity Measurement (Rev. B)
    PDF, 262 Кб, Версия: B, Файл опубликован: 6 май 2013
    Of all common environmental parameters humidity is perhaps the least understood and most difficult tomeasure. The most common electronic humidity detection methods albeit highly accurate are not obviousand tend to be expensive and complex (See Box). Accurate humidity measurement is vital to a number ofdiverse areas including food processing paper and lumber production pollution monitor
  • AB-12 Wide Adjustable Range PNP Voltage Regulator (Rev. B)
    PDF, 47 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the PNP voltage regulator.
  • Packaging Limits Range of Linear Regulators
    PDF, 75 Кб, Файл опубликован: 8 май 2010
    The power limitations of the physical packaging for a linear regulator device can limit the total output current or the input-to-output voltage differential. This inherent limitation is not always apparent from the product data sheet and must be evaluated during the design phase. This application note shows how the package can limit the operating envelope of a linear regulator.
  • AN-298 Isolation Techniques for Signal Conditioning (Rev. B)
    PDF, 685 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note provides information and examples of isolation techniques for signal conditioning.
  • AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)
    PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
    The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
  • Digital Designer's Guide to Linear Voltage Regulators & Thermal Mgmt (LDO) (Rev. A)
    PDF, 509 Кб, Версия: A, Файл опубликован: 4 июн 2008
  • AN-181 3-Terminal Regulator is Adjustable (Rev. B)
    PDF, 314 Кб, Версия: B, Файл опубликован: 5 май 2013
    Until now all of the 3-terminal power IC voltage regulators have a fixed output voltage. In spite of this limitation their ease of use low cost and full on-chip overload protection have generated wide acceptance. Now with the introduction of the LM117 it is possible to use a single regulator for any output voltage from 1.2 V to 37 V at 1.5A. Selecting close-tolerance outp
  • AN-1148 Linear Regulators: Theory of Operation and Compensation (Rev. B)
    PDF, 300 Кб, Версия: B, Файл опубликован: 6 май 2013
    This application note discusses the operation and compensation of linear regulators.
  • Super Matched Bipolar Transistor Pair Sets New Standards for Drift and Noise (Rev. B)
    PDF, 966 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses how a super matched bipolar transistor pair sets new standards for driftand noise.
  • AN-103 LM340 Series Three Terminal Positive Regulators (Rev. A)
    PDF, 814 Кб, Версия: A, Файл опубликован: 6 май 2013
    The LM340-XX are three terminal 1.0A positive voltage regulators with preset output voltages of 5.0V or15V. The LM340 regulators are complete 3-terminal regulators requiring no external components fornormal operation. However by adding a few parts one may improve the transient response provide for avariable output voltage or increase the output current. Included on the chip are all of t
  • Understanding the Terms and Definitions of LDO Voltage Regulators
    PDF, 197 Кб, Файл опубликован: 21 окт 1999
    This report provides an understanding of the terms and definitions of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current standby current efficiency transient response line/load regulation power supply rejection output noise voltage accuracy and power dissipation. Each section includes an example to increase the understandab
  • AN-182 Improving Power Supply Reliability with IC Power Regulators (Rev. B)
    PDF, 82 Кб, Версия: B, Файл опубликован: 5 май 2013
    This application report discusses improving power supply reliability with IC power regulators.
  • LM143 Monolithic High Voltage Operational Amplifier Applications
    PDF, 479 Кб, Файл опубликован: 2 май 2004
    Application Note 127 LM143 Monolithic High Voltage Operational Amplifier Applications
  • Industrial-strength design considerations to prevent thermal and EMI damage
    PDF, 282 Кб, Файл опубликован: 11 апр 2014
  • Method For Cal Output Voltage Tolerances in Adj Regs (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 5 май 2013
    When working with voltage regulator circuits the designer is often confronted with the need to calculatethe tolerance of the regulated output voltage. For fixed voltage regulators this problem is easily managedbecause the required information is directly supplied on the semiconductor manufacturer's data sheet.
LM340T15/NOPB, LM340T 15/NOPB
На английском языке: Datasheet Texas Instruments LM340T-15/NOPB
