Datasheet Texas Instruments TMS320F28075PTPS — Даташит
СерияTMS320F28075
МодельTMS320F28075PTPS
Микроконтроллер Piccolo 176-HLQFP от -40 до 125
TMS320F2807x Piccoloв„ў Microcontrollers datasheet
PDF, 1.7 Мб, Версия: D, Файл опубликован: 25 июл 2017
Pin176176
Package TypePTPPTP
Industry STD TermHLQFPHLQFP
JEDEC CodeS-PQFP-GS-PQFP-G
Package QTY4040
МаркировкаF28075PTPSTMS320
Width (мм)2424
Length (мм)2424
Thickness (мм)1.41.4
Pitch (мм).5.5
Max Height (мм)1.61.6
ADC17,14 Ch
ADC Resolution12-bit
CAN2
CPUC28x,CLA
Comparators8
DMA6 Ch
FPUYes
Flash512 KB
Тактовая частота120 МГц
High Resolution PWM16,9 Ch
I2C2
Рабочий диапазон температурот -40 до 105,-40 до 125 C
PWM24,15 Ch
Pin/Package100HTQFP, 176HLQFP
QEP3,2
RAM100 KB
SPI3
Total Processing240 MIPS
UART4,3 SCI
USB1
    XDS200 USB Debug Probe
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • Development Kits: TMDXCNCD28075
    Piccolo F28075 controlCARD Kit
  • Development Kits: TMDXDOCK28075
    Piccolo F28075 Experimenter’s Kit
  • Evaluation Modules & Boards: TMDXIDDK377D
    C2000 DesignDRIVE Development Kit for Industrial Motor Control
    Статус продукта: NRND (Не рекомендуется для новых разработок)
  • A Technical Introduction to the TMS320F28004x Microcontroller
    PDF, 549 Кб, Файл опубликован: 23 мар 2017
    While many real-time control systems require a high-performance microcontroller (MCU), the tradeoffs of balancing performance and cost can be challenging. To this end, Texas Instruments developed the Piccoloв„ў TMS320F28004x MCU device series. This document discusses the technical details of the TMS320F28004x architecture and highlights the new improvements to various key peripherals, such as
  • CW/CCW Support on the C2000 eQEP Module
    PDF, 663 Кб, Файл опубликован: 13 авг 2014
    This application report describes two methods of interfacing a pulse train output (PTO) of clockwise and counterclockwise (CW/CCW) signals with the C2000 enhanced quadrature encoder pulse (eQEP) module. The eQEP module can be used to count the number of pulses, note the direction of motion, and calculate other variables such as position and velocity using the input signals.
  • High-Performance, High-Precision, Smart Sensing for Industrial Drives
    PDF, 41 Кб, Файл опубликован: 11 май 2016
    In higher end control applications such as servo drives, high-resolution feedback is required to provideprecise phase current measurements for low-torque ripple and precision positioning; however, for somemeasurements, precise sample rates are more important than higher resolution, such as when makinghigh-speed, low-side shunt current measurements. To support different accuracy requirements,
  • Built-In System Protection for Industrial Drives
    PDF, 58 Кб, Файл опубликован: 11 май 2016
    Eight windowed comparators are integrated into the Delfino F2837xD MCU architecture, providing “trip points,” and operate independently from the CPU so there is no additional CPU loading. The comparators are also fast acting (50 ns reaction to trip!) and CPU independent to minimize latency with trip signals so the system can react quickly to any abnormal events or over/under limit conditions. The
  • Flexible PWMs Enable Multi-Axis Drives, Multi-Level Inverters
    PDF, 39 Кб, Файл опубликован: 11 май 2016
    High-performance control peripherals are an integral component for all digital control systems. The hallmark of the Delfino F2837xD devices are the control peripherals including the flexible, powerful, industry-proven PWM timers. Each of the PWM modules is enhanced to support high resolution capabilities on both A and B channels. These high-resolution channels extend 150ps PWM step resolution to e
  • Accessing External SDRAM on the TMS320F2837x/280 Microcontrollers Using C/C++
    PDF, 62 Кб, Файл опубликован: 30 мар 2015
    The TMS320F2837x and TMS320F2807x microcontrollers provide facilities for interfacing to external SDRAM memory through two external memory interface modules. The address space for this memory lies beyond the 22-bit addressable range traditionally accessed with the C28x CPU. This application report describes how to access the SDRAM memory from C/C++ code.
  • Sensored Field Oriented Control of 3-Phase Perm Magnet Sync Motors Using F2827x
    PDF, 1.2 Мб, Файл опубликован: 12 фев 2016
    This application report presents a solution to control a permanent magnet synchronous motor (PMSM) using the TMS320F2837x microcontrollers. TMS320F2837x devices are part of the family of C2000 microcontrollers, which enables the cost-effective design of intelligent controllers for three phase motors by reducing system components and increasing efficiency. With these devices, it is possible to real
  • The TMS320F2837xD Architecture: Achieving a New Level of High Performance
    PDF, 384 Кб, Файл опубликован: 11 фев 2016
    With the utilization of advanced high-performance microcontroller architectures, sophisticated real-time control systems can be realized. By combining both analog and digital control peripherals into a single device, along with a dual-core design, these systems can be cost-effectively implemented. This document provides an introduction and general overview to the TMS320F2837xD device architectural
  • PRIME PLC Device Firmware Upgrade
    PDF, 578 Кб, Файл опубликован: 10 июл 2013
  • Interfacing the C2000 with an AFE03x: B-FSK Example
    PDF, 2.7 Мб, Файл опубликован: 30 июн 2017
    This application report provides information on how to interface a C2000 device with an AFE031, and send data over a wired coupled interface using frequency shift keying. A demonstration of transmitting FSK information is discussed with tone frequencies in the 130-145 kHz range.
  • Sensorless Field Oriented Control of 3-Phase Induction Motors Using F2833x
    PDF, 1.9 Мб, Файл опубликован: 29 окт 2013
    This application report presents a solution to control an AC induction motor using floating point TMS320F2833x microcontrollers. TMS320F2833x devices are part of the family of C2000в„ў microcontrollers which enable cost-effective design of intelligent controllers for three phase motors by reducing the system components and increase efficiency. With these devices it is possible to realize far m
  • Sensorless Field Oriented Control:3-Phase Perm.Magnet Synch. Motors Using 2833x
    PDF, 1.9 Мб, Файл опубликован: 1 июл 2013
    This application report presents a solution to control a permanent magnet synchronous motor (PMSM)using the TMS320F2833x floating-point microcontrollers. TMS320F2833x devices are part of the family ofC2000 microcontrollers, which enables the cost-effective design of intelligent controllers for three phasemotors by reducing system components and increasing efficiency. With these devices, it i
  • Using the eQEP Module in TMS320x280x as a Dedicated Capture
    PDF, 179 Кб, Файл опубликован: 30 ноя 2006
    This document provides a guide for the use of the eQEP module as a dedicated capture unit and is applicable to the TMS320x280x, 28xxx family of processors.
  • Interfacing the TMS320F2833x to the AIC23B Stereo Audio Codec
    PDF, 910 Кб, Файл опубликован: 4 авг 2008
    This application report describes the implementation of an audio application using the TLV320AIC23B stereo audio codec interfaced to the TMS320F28335 digital signal controller and the setup of the multi-channel buffered serial port (McBSP) and direct memory access (DMA) module to support the application.
  • A Numerical Protection Relay Solution
    PDF, 187 Кб, Файл опубликован: 2 сен 2010
    Numerical Protection Relays (NPRs) are critical elements in any power distribution network. Generally, there are several different types of NPRs. Each type, however, shares a similar architecture, thus enabling designers to build an entire system solution that is based on a relatively small number of flexible components. This application note demonstrates how an NPR can be implemented using TI's e
  • Using Enhanced Pulse Width Modulator (ePWM) Module for 0-100% Duty Cycle Control
    PDF, 123 Кб, Файл опубликован: 20 дек 2006
    This document provides a guide for the use of the ePWM module to provide 0% to 100% duty cycle control and is applicable to the TMS320x280x family of processors.
  • TMS320F280x DSC USB Connectivity Using TUSB3410 USB-to-UART Bridge Chip
    PDF, 511 Кб, Файл опубликован: 26 май 2006
    USB connectivity on the TMS320F280xв„ў family of Digital Signal Controllers may be achieved using the TUSB3410 USB 2.0 to UART bridge chip. All needed USB descriptors and firmware for the TUSB3410 device are bootable from the on-chip memory of the TMS320F280x device through the I2C port, and hence an external EEPROM is not needed in the system. A USB development system for the TMS320F2808 is e
  • Calculating Useful Lifetimes of Embedded Processors
    PDF, 521 Кб, Файл опубликован: 11 ноя 2014
    This application report provides a methodology for calculating the useful lifetime of TI embedded processors (EP) under power when used in electronic systems. It is aimed at general engineers who wish to determine if the reliability of the TI EP meets the end system reliability requirement.
  • Getting Started With TMS320C28x Digital Signal Controllers (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 25 окт 2007
    This guide is organized by development flow and functional areas to make your design effort as seamless as possible. Tips on getting started with TMS320C28xв„ў DSP software and hardware development are provided to aid in your initial design and debug efforts. Each section includes pointers to valuable information including technical documentation, software, and tools for use in each phase of d
  • TMS320C28x FPU Primer (Rev. A)
    PDF, 228 Кб, Версия: A, Файл опубликован: 20 июл 2009
    This primer provides an overview of the floating-point unit (FPU) in the C2000в„ў Delfino microcontroller devices.
  • Power Line Communication for Lighting Apps using BPSK w/ a Single DSP Controller
    PDF, 1.7 Мб, Файл опубликован: 7 мар 2006
    DSP controllers provide the on-chip peripherals and computational power needed to implement various power electronics applications. A single-chip DSP controller allows designers to implement multiple functions such as power line communication, power-factor correction, and inverter control, all needed for an overall dimmable lighting ballast application. This application report presents a complete
  • Configuring Source of Multiple ePWM Trip-Zone Events
    PDF, 93 Кб, Файл опубликован: 25 окт 2007
    Applications that require PWM outputs to respond to multiple trip-zones (TZ) are challenged to determine the specific source of the TZ event.This application report describes how to configure an ePWM module to identify the specific source of a TZ event when multiple TZ events are enabled to act on a single PWM channel.
  • Custom Bootloader Options via One-Time Programmable (OTP) Memory
    PDF, 62 Кб, Файл опубликован: 18 сен 2007
    The Boot to One-Time-Programmable (OTP) memory mode in the TMS320x280x devices provides the necessary hooks to support custom bootloaders. This is very useful in a situation where a bootloader option, required by a specific customer application, is not already supported as one of the built-in options in the Boot read-only memory (ROM). This application report includes information and examples on h
  • Interfacing SD/MMC Cards With TMS320F28xxx DSCs
    PDF, 1.3 Мб, Файл опубликован: 26 июл 2007
    This application report and associated code implements the interfacing of Secure Digital (SD) or Multi-Media Card (MMC) types of Flash memory cards with the TMS320F28xxx digital signal controllers (DSCs). These cards can use serial peripheral interface (SPI) or parallel (SD) interface to connect to the host. This application report demonstrates the SPI mode and includes the schematics showing th
  • An Easy Way of Creating a C-callable Assembly Function for the TMS320C28x DSP
    PDF, 185 Кб, Файл опубликован: 30 окт 2001
    C-callable assembly routines require an understanding of parameter-passing conventions and environments expected by the C compiler. This application report provides instructions and suggestions to configure the C compiler to assist with these issues.
  • An Overview of Designing Analog Interface With TM320F28xx/28xxx DSCs (Rev. A)
    PDF, 655 Кб, Версия: A, Файл опубликован: 14 май 2008
    This application report provides guidelines that take you through everything from configuring the ADC and related registers correctly, responding to interrupts, and board design recommendations; this may be particularly useful for first-time users of the TMS320C2000в„ў digital signal processor (DSP) platform devices and for firmware engineers with less exposure to the analog world. Various s
  • Copying Compiler Sections from Flash to RAM on the TMS320F28xxx DSCs (Rev. A)
    PDF, 307 Кб, Версия: A, Файл опубликован: 18 авг 2017
    This application report and associated code files provide functionality for copying initialized compiler sections from the internal Flash memory to the internal random access memory (RAM) of the TMS320F28xxx digital signal controllers (DSCs) at run time for optimizing execution speed. The solution provided implements this functionality directly after booting before entering the c_int00 C entry rou
  • Online Stack Overflow Detection on the TMS320C28x DSP
    PDF, 407 Кб, Файл опубликован: 2 май 2003
    A stack overflow in an embedded DSP application generally produces a catastrophic software crash due to data corruption, lost return addresses, or both. Traditional off-line approaches to sizing a stack during development, such as filling with a know value, or estimating based on code content, are not 100% reliable. Therefore, programmers often feel compelled to reserve larger stack sizes than are
  • Using PWM Output as a Digital-to-Analog Converter on a TMS320F280x (Rev. A)
    PDF, 381 Кб, Версия: A, Файл опубликован: 9 сен 2008
    This application report presents a method for utilizing the on-chip pulse width modulated (PWM) signal generators on the TMS320F280xв„ў family of digital signal controllers as a digital-to-analog converter (DAC). The method involves analog low-pass filtering the PWM signal to remove high frequency components, leaving only the low-frequency content. Theoretical and experimental results are presented
  • Running an Application from Internal Flash Memory on the TMS320F28xxx DSP (Rev. L)
    PDF, 641 Кб, Версия: L, Файл опубликован: 28 фев 2013
    Several special requirements exist for running an application from on-chip Flash memory on the TMS320F28xxx. These requirements generally do not manifest themselves during code development in RAM since the Code Composer Studioв„ў (CCS) debugger can mask problems associated with initialized sections and their linkage in memory. This application report covers the application software modificatio
  • Flash Programming Solutions for the TMS320F28xxx DSCs
    PDF, 423 Кб, Файл опубликован: 19 авг 2008
    Flash programming is a process that occurs during all stages of a TMS320F28xxx digital signal controller (DSC) development cycle: firmware debug, prototyping, production, and field reprogramming. Several solutions are available to accommodate programming for all of these development stages. This application report presents solutions that are available and at what stage in the development cycle the
  • Programming TMS320x28xx and 28xxx Peripherals in C/C++ (Rev. D)
    PDF, 530 Кб, Версия: D, Файл опубликован: 27 фев 2013
    This application report explores a hardware abstraction layer implementation to make C/C++ coding easier on C28x devices. This method is compared to traditional #define macros and topics of code efficiency and special case registers are also addressed.
  • Accelerators: Enhancing the Capabilities of the C2000 MCU Family Technical Brief (Rev. A)
    PDF, 155 Кб, Версия: A, Файл опубликован: 8 ноя 2016
    Engineers designing real-time control systems are constantly faced with the challenge of optimizing performance. These systems require minimal processing latency in order to meet the control loop performance specifications. At the heart of the control systems are math intensive algorithms which are used to calculate the control signals. Utilizing a microcontroller (MCU) that can quickly and effici
  • Serial Flash Programming of C2000 Microcontrollers (Rev. B)
    PDF, 387 Кб, Версия: B, Файл опубликован: 8 фев 2017
    Often times, embedded processors must be programmed in situations where JTAG is not a viable optionfor programming the target device. When this is the case, the engineer must rely on some type of serial programming solution. C2000 devices aid in this endeavor through their inclusion of several program loading utilities included in ROM. These utilities are useful, but only solve half of the progr
  • EEPROM Emulation With the TMS320F28xxx DSCs
    PDF, 407 Кб, Файл опубликован: 21 сен 2009
    Many applications require storing small quantities of system related data (e.g., calibration values, device configuration) in a non-volatile memory, so that it can be used or modified and reused even after power cycling the system. EEPROMs are primarily used for this purpose. EEPROMs have the ability to erase and write individual bytes of memory many times over and the programmed locations retain
  • Calculator for CAN Bit Timing Parameters
    PDF, 37 Кб, Файл опубликован: 22 мар 2016
    Controller Area Network (CAN) nodes use user-specified timing parameters to sample the asynchronous bitstream and recover the clock. These parameters are typically based on the frequency of the available reference oscillator. There may be several options available for a given frequency, and some of them will allow a looser oscillator tolerance than others. This application report details the creat
  • Programming External Nonvolatile Memory Using SDFlash for TMS320C28x Devices
    PDF, 2.0 Мб, Файл опубликован: 16 ноя 2009
    The C28xxx generation of microcontrollers can connect to external nonvolatile memory through a variety of interfaces including parallel, serial peripheral interface (SPI), and inter-integrated circuit (I2C). This application report discusses how to write drivers for your external nonvolatile memory to allow for in-place programming using SDFlash, an application provided by Spectrum Digital, Inc. A
  • Common Object File Format (COFF)
    PDF, 125 Кб, Файл опубликован: 15 апр 2009
  • TPS75005 Quick-Start Guide with C2000 Controllers
    PDF, 129 Кб, Файл опубликован: 17 янв 2012
    The TPS75005 is a complete power management solution for C2000 controllers from Texas Instruments. This document illustrates how to attach the TPS75005 to a C2000 controller.
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
  • Semiconductors > Microcontrollers (MCU) > Performance MCUs > Real-time Control > Piccolo F2802x/3x/5x/6x/7x
На английском языке: Datasheet Texas Instruments TMS320F28075PTPS
