Datasheet Texas Instruments SN74LVC16245AGRDR — Даташит
СерияSN74LVC16245A
МодельSN74LVC16245AGRDR
16-битный шинный трансивер с выходами с 3 состояниями 54 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVC16245A 16-Bit Bus Transceiver With 3-State Outputs datasheet
PDF, 1.0 Мб, Версия: Q, Файл опубликован: 5 июн 2014
Pin54
Package TypeGRD
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Width (мм)5.5
Length (мм)8
Thickness (мм).8
Pitch (мм).8
Max Height (мм)1.2
Рекомендуемая замена
ReplacementSN74LVC16245AZRDR
Replacement CodeP
Approx. Price (US$)0.49 | 1ku
Bits(#)16
F @ Nom Voltage(Max)(Mhz)100
ICC @ Nom Voltage(Max)(mA)0.02
Тип входаTTL/CMOS
Operating Temperature Range(C)-40 to 125
-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаLVTTL
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L (PKG)56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR)
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)7.1
4.5
4.7
4
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVC16245AGRDR
