Datasheet Texas Instruments LM393DRE4 — Даташит
СерияLM393
МодельLM393DRE4
Двойной дифференциальный компаратор 8-SOIC от 0 до 70
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
Микросхема Компаратор, TEXAS INSTRUMENTS LM393DRE4 Analog Comparator, Dual, Differential, 2, 300ns, 2V to 36V, SOIC, 8Pins
LM393DRE4
от 3.01 ₽
LM393DRE4
8.46 ₽
LM393DRE4
10 ₽
Hi-Tech Circuit Group
LM393DRE4
Package TypeD
Package QTY2500
МаркировкаLM393
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Input Bias Current (+/-)(Max)50 нА
Iq per channel(Max)0.5 мА
Количество каналов2
Тип выходаOpen Collector
Propagation Delay Time0.3 uS
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)34.5 В
Vos (Offset Voltage @ 25C)(Max)5 мВ
Vs(Max)36 В
Vs(Min)2 В
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM393DRE4
