Datasheet Texas Instruments TPS799285DDCR — Даташит
Серия | TPS799 |
Модель | TPS799285DDCR |
Линейный стабилизатор 5-SOT-23-THIN от -40 до 125, 200 мА, низкий ток покоя, сверхнизкий уровень шума, высокий PSRR и малое падение напряжения.
TPS799 200-mA, Low-Quiescent Current, Ultralow Noise, High-PSRR Low-Dropout Linear Regulator datasheet
PDF, 1.3 Мб, Версия: K, Файл опубликован: 5 янв 2011
Pin | 5 |
Package Type | DDC |
Industry STD Term | SOT-23-THIN |
JEDEC Code | R-PDSO-G |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | AXY |
Width (мм) | 1.6 |
Length (мм) | 2.9 |
Thickness (мм) | .87 |
Pitch (мм) | .95 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Точность | 2 % |
Fixed Output Options | 1.2,1.25,1.3,1.5,1.8,1.85,1.9,1.95,2,2.1,2.5,2.6,2.7,2.75,2.8,2.85,3,3.15,3.2,3.3,4.2,4.5 В |
Iout(Max) | 0.2 A |
Iq(Typ) | 0.04 мА |
Noise | 29 uVrms |
Output Capacitor Type | Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 38 дБ |
Package Group | SOT-23-THIN |
Package Size: mm2:W x L | 5SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Enable |
Thermal Resistance ОёJA | 74 В°C/W |
Vdo(Typ) | 100 мВ |
Vin(Max) | 6.5 В |
Vin(Min) | 2.7 В |
Vout(Max) | 6.5 В |
Vout(Min) | 1.2 В |
- Evaluation Modules & Boards: TPS799XXEVM-105
TPS799xx Evaluation Module
- Understanding LDO DropoutPDF, 52 Кб, Файл опубликован: 9 май 2005
Not all low dropout (LDO) linear regulator data sheets provide the voltage dropout information needed for all applications. This application report shows a designer how to use an LDO data sheet's specified dropout performance to determine the dropout voltage at other operating conditions. - Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
Серия: TPS799 (100 из 120)
- TPS79912YZUT TPS79913DDCR TPS79913DDCT TPS79913DDCTG4 TPS79913YZUR TPS79913YZUT TPS79915DDCR TPS79915DDCRG4 TPS79915DDCT TPS79915DDCTG4 TPS79915YZUR TPS79915YZUT TPS799185DDCR TPS799185DDCRG4 TPS799185DDCT TPS799185YZUR TPS799185YZUT TPS79918DDCR TPS79918DDCRG4 TPS79918DDCT TPS79918DDCTG4 TPS79918DRVR TPS79918DRVRG4 TPS79918DRVT TPS79918DRVTG4 TPS79918YZUR TPS79918YZUT TPS799195DRVR TPS799195DRVRG4 TPS799195DRVT TPS799195DRVTG4 TPS799195YZUR TPS799195YZUT TPS79919YZUR TPS79919YZUT TPS79920YZUR TPS79920YZUT TPS79921YZUR TPS79921YZUT TPS79925DDCR TPS79925DDCRG4 TPS79925DDCT TPS79925DDCTG4 TPS79925YZUR TPS79925YZUT TPS79926YZUR TPS79926YZUT TPS799275YZUR TPS799275YZUT TPS79927DDCR TPS79927DDCT TPS79927DRVR TPS79927DRVT TPS79927DRVTG4 TPS79927YZUT TPS799285DDCR TPS799285DDCRG4 TPS799285DDCT TPS799285DDCTG4 TPS799285DRVR TPS799285DRVT TPS799285YZUR TPS79928DDCR TPS79928DDCRG4 TPS79928DDCT TPS79928DDCTG4 TPS79928DRVR TPS79928DRVRG4 TPS79928DRVT TPS79928DRVTG4 TPS79928YZUR TPS79928YZUT TPS79930DDCR TPS79930DDCRG4 TPS79930DDCT TPS79930DDCTG4 TPS79930YZUR TPS79930YZUT TPS799315DDCR TPS799315DDCRG4 TPS799315DDCT TPS799315YZUR TPS799315YZUT TPS79932YZUR TPS79932YZUT TPS79933DDCR TPS79933DDCRG4 TPS79933DDCT TPS79933DDCTG4 TPS79933DRVR TPS79933DRVRG4 TPS79933DRVT TPS79933DRVTG4 TPS79933YZUR TPS79933YZUT TPS79942DDCR TPS79942DDCRG4 TPS79942DDCT TPS79945YZUR TPS79945YZUT
