Datasheet Texas Instruments SN74LVC16244DGGR — Даташит
СерияSN74LVC16244
МодельSN74LVC16244DGGR
16-битный буфер/драйвер с выходами с 3 состояниями 48-TSSOP от -40 до 85
Datasheet
TSP
Pin48
Package TypeDGG
Industry STD TermTSSOP
Width (мм)6.1
Length (мм)12.5
Thickness (мм)1.15
Pitch (мм).5
Max Height (мм)1.2
RoHSНе совместим
  • Simultaneous-Switching Performance of TI Logic Devices (Rev. B)
    PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
    Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC16244 (3)
На английском языке: Datasheet Texas Instruments SN74LVC16244DGGR
