Datasheet Texas Instruments TL5001CDRG4 — Даташит
СерияTL5001
МодельTL5001CDRG4
ШИМ-контроллер с широким входным диапазоном 8-SOIC от -25 до 85
Pulse-Width-Modulation Control Circuits datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 31 янв 2002
Package TypeD
Package QTY2500
Маркировка5001C
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Duty Cycle(Max)100 %
Iout(Max)3 A
Iq(Typ)1.1 мА
Рабочий диапазон температурот -25 до 85,-40 до 125,-40 до 85 C
Special FeaturesN/A
Switch Current Limit(Min)3 A
Switching Frequency(Max)400 kHz
Switching Frequency(Min)50 kHz
TopologyBoost,Buck,Flyback,Forward,Inverting,SEPIC
ТипController
Vin(Max)40 В
Vin(Min)3.6 В
Vout(Max)50 В
Vout(Min)1 В
  • Evaluation Modules & Boards: TL5001EVM-097
    PWM Buck Controller with Selectable 3.3V or 5V Output
  • Examples Of Applications With The Pulse Width Modulator TL5001
    PDF, 462 Кб, Файл опубликован: 1 янв 1997
    Switched-mode techniques are used more and more nowadays for the design of power supplies. Switch mode power supplies have considerably higher efficiency when compared to designs employing linear regulators, and can be used for higher output powers. The rectified input voltage in a switching regulator is chopped by means of a switch. The LC network after the switch smoothes this voltage, resulting
  • Designing with the TL5001 PWM Controller (Rev. A)
    PDF, 265 Кб, Версия: A, Файл опубликован: 1 сен 1995
    Electrical and electronic products required to be lighter, smaller, use less power, and cost less. Manufacturers are turning to small high-frequency dc-to-dc converters for the power supply solution. The TL5001, pulse-width modulator (PWM) control integrated circuit, when combined with a few external components, can implement the converters and operate at frequencies to 400 kHz. This document p
  • Practical Feedback Loop Analysis for Voltage-Mode Boost Converter
    PDF, 559 Кб, Файл опубликован: 4 фев 2014
  • Off-Line SMPS Failure Modes PWM Switchers and DC-DC Converters
    PDF, 71 Кб, Файл опубликован: 22 мар 2000
    Today's voltage regulator modules (VRMs) employ off-line SMPS techniques. Traditionally, they are usually discarded when they fail because they are so challenging to debug and so inexpensive to replace. Investigation of these failed modules reveals some common failure modes. Some failures are caused by other systems' passive components that fail after repeated electrical stress. Recognizing these
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Buck/Boost, Inverting or Split-Rail > Buck/Boost or Inverting Controller (External Switch)
На английском языке: Datasheet Texas Instruments TL5001CDRG4
