Datasheet Texas Instruments SN74LVT245BDBLE — Даташит
| Серия | SN74LVT245B |
| Модель | SN74LVT245BDBLE |
Приемопередатчики восьмеричной шины ABT 3,3 В с выходами с 3 состояниями 20-SSOP от -40 до 85
SN74LVT245B datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 9 сен 2003
3.3-V ABT Octal Bus Transceivers With 3-State Outputs 20-SSOP -40 to 85 | |||
| SN74LVT245BDBLE Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 20 |
| Package Type | DB |
| Industry STD Term | SSOP |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 5.3 |
| Length (мм) | 7.2 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | .65 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Approx. Price (US$) | 0.27 | 1ku |
| Bits(#) | 8 |
| F @ Nom Voltage(Max)(Mhz) | 160 |
| ICC @ Nom Voltage(Max)(mA) | 5 |
| Тип входа | TTL/CMOS |
| Operating Temperature Range(C) | -40 to 85 |
| Output Drive (IOL/IOH)(Max)(mA) | -32/64 |
| Тип выхода | LVTTL |
| Package Group | SSOP |
| Package Size: mm2:W x L (PKG) | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVT |
| VCC(Max)(V) | 3.6 |
| VCC(Min)(V) | 2.7 |
| Voltage(Nom)(V) | 3.3 |
| tpd @ Nom Voltage(Max)(ns) | 3.5 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- LVT Family Characteristics (Rev. A)PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti - LVT-to-LVTH ConversionPDF, 84 Кб, Файл опубликован: 8 дек 1998
Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
Серия: SN74LVT245B (18)
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
