Datasheet Texas Instruments CD54HC162F3A — Даташит
Серия | CD54HC162 |
Модель | CD54HC162F3A |
Высокоскоростные синхронные десятичные счетчики BCD с логикой КМОП и синхронным сбросом 16-CDIP от -55 до 125
7 предложений от 7 поставщиков High Speed CMOS Logic Synchronous BCD Decade Counters with Synchronous eset 16-CDIP -55 to 125 | |||
CD54HC162F3A | по запросу | ||
CD54HC162F3A8409401EA Texas Instruments | по запросу | ||
CD54HC162F3A Texas Instruments | по запросу | ||
CD54HC162F3A Rochester Electronics | по запросу |
Pin | 16 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Width (мм) | 6.92 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Selecting the Right Texas Instruments Signal SwitchPDF, 769 Кб, Файл опубликован: 7 сен 2001
Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi - Using High Speed CMOS and Advanced CMOS in Systems With Multiple VccPDF, 43 Кб, Файл опубликован: 1 апр 1996
Though low power consumption is a feature of CMOS devices sometimes this feature does not meet a designer?s system power supply constraints. Therefore a partial system power down or multiple Vcc supplies are used to meet the needs of the system. This document shows electrostatic discharge protection circuits. It also provides circuit and bus driver examples of partial system power down and curren - SN54/74HCT CMOS Logic Family Applications and RestrictionsPDF, 102 Кб, Файл опубликован: 1 май 1996
Серия: CD54HC162 (1)
- CD54HC162F3A
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
