Datasheet Texas Instruments THS4131IDGKG4 — Даташит
СерияTHS4131
МодельTHS4131IDGKG4
Полностью дифференциальный малошумящий усилитель ввода/вывода 8-VSSOP от -40 до 85
THS413x High-Speed, Low-Noise, Fully-Differential I/O Amplifiers datasheet
PDF, 1.6 Мб, Версия: I, Файл опубликован: 31 авг 2015
IC OPAMP DIFF 1 CIRCUIT 8VSSOP. Differential Amplifier 1 Circuit Differential 8-VSSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
THS4131IDGKG4
261 ₽
Рутоника
THS4131IDGKG4
599 ₽
LifeElectronics
THS4131IDGKG4
THS4131IDGKG4
Package TypeDGK
Industry STD TermVSSOP
Package QTY80
МаркировкаASP
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic88 dBc
3rd Harmonic84 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураFully Differential,Voltage FB
BW @ Acl150 МГц
CMRR(Min)80 дБ
CMRR(Typ)95 дБ
GBW(Typ)170 МГц
Input Bias Current(Max)6000000 pA
Iq per channel(Max)15 мА
Iq per channel(Typ)12.3 мА
Количество каналов1
Offset Drift(Typ)4.5 uV/C
Output Current(Typ)85 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)52 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)4 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.5 нВ/rtГц
Vn at Flatband(Typ)1.3 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)2 мВ
  • Evaluation Modules & Boards: THS4131EVM
    THS4131EVM Evaluation Module
  • Evaluation Modules & Boards: THS4140EVM
    THS4140EVM Evaluation Module
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
  • Designing for low distortion with high-speed op amps
    PDF, 277 Кб, Файл опубликован: 2 мар 2005
На английском языке: Datasheet Texas Instruments THS4131IDGKG4
