Datasheet Texas Instruments DAC8534IPWR — Даташит
СерияDAC8534
МодельDAC8534IPWR
От 2,7 до 5,5 В, четырехканальный, 16-битный ЦАП с последовательным входом 16-TSSOP от -40 до 105
DAC8534: Quad Channel, Low Power, 16-Bit, Serial Input D/A Converter datasheet
PDF, 965 Кб, Версия: D, Файл опубликован: 30 мар 2004
АЦП азиатских производителей
Pin16
Package TypePW
Industry STD TermTSSOP
Package QTY2000
МаркировкаD8534I
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Code to Code Glitch(Typ)20 nV-sec
DAC ArchitectureString
DAC Channels4
Gain Error(Max)1 %FSR
INL(Max)64 +/-LSB
InterfaceSPI
Offset Error(Max)N/A %
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupTSSOP
Package Size: mm2:W x L16TSSOP: 32 mm2: 6.4 x 5(TSSOP) PKG
Power Consumption(Typ)2.7 mW
Reference: TypeExt
Разрешение16 Bits
Sample / Update Rate0.093 MSPS
Время установления10 µs
Special FeaturesN/A
Zero Code Error(Typ)20 мВ
  • Evaluation Modules & Boards: DAC8534EVM
    DAC8534 Evaluation Module
  • Interfacing the DAC8534EVM to TMS320C5x Processors
    PDF, 211 Кб, Файл опубликован: 30 янв 2004
    The DAC8534 is a quad-channel, low-power, 16-bit, serial digital-to-analog converter. This application report describes a method for interfacing the DAC8534 to the TMS320C5x-series DSKs using McBSP1 and the 5-6K Interface Board. The software developed for this application creates a 256-point sine table, then continuously writes values from the sine table to the DAC8534. To reduce development time,
  • Interfacing the DAC8534EVM to TMS320C6x Processors
    PDF, 235 Кб, Файл опубликован: 30 янв 2004
    The DAC8534 is a quad-channel, low-power, 16-bit, serial digital-to-analog converter. This application report presents a method for interfacing the DAC8534 to the TMS320C6x-series DSKs using McBSP1 and the 5-6K Interface Board. The software developed for this application creates a 256-point sine table, then continuously writes values from the sine table to the DAC8534. To reduce development time,
  • Interfacing the DAC8534 to the TMS320VC33 DSP
    PDF, 208 Кб, Файл опубликован: 3 сен 2003
    This application report describes how to interface the DAC8534 digital-to-analog converter to the TMS320VC33 digital signal processing.
Серия: DAC8534 (4)
На английском языке: Datasheet Texas Instruments DAC8534IPWR
