Линейка продуктов KEEN SIDE
Datasheet Texas Instruments SN74AS1004ANSR — Даташит
СерияSN74AS1004A
МодельSN74AS1004ANSR
Шестнадцатеричные инвертирующие драйверы 14-SO от 0 до 70
Hex Inverting Drivers datasheet
PDF, 913 Кб, Версия: B, Файл опубликован: 1 янв 1995
Pin14
Package TypeNS
Industry STD TermSOP
Package QTY2000
Маркировка74AS1004A
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Bits6
F @ Nom Voltage(Max)125 Mhz
ICC @ Nom Voltage(Max)0.012 мА
Output Drive (IOL/IOH)(Max)-48/48 мА
Package GroupSO
Package Size: mm2:W x L14SO: 80 mm2: 7.8 x 10.2(SO) PKG
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)7 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
На английском языке: Datasheet Texas Instruments SN74AS1004ANSR
