Datasheet Texas Instruments UC382TD-ADJ — Даташит
Серия | UC382 |
Модель | UC382TD-ADJ |
3-A, быстрый линейный регулятор LDO 5-DDPAK/TO-263 от 0 до 100
UC282-x, UC382-x: Fast LDO Linear Regulator datasheet
PDF, 882 Кб, Версия: B, Файл опубликован: 23 фев 2004
Pin | 5 |
Package Type | KTT |
Industry STD Term | TO-263 |
JEDEC Code | R-PSFM-G |
Width (мм) | 8.42 |
Length (мм) | 10.16 |
Thickness (мм) | 4.58 |
Pitch (мм) | 1.7 |
Max Height (мм) | 4.83 |
Mechanical Data | Скачать |
Рекомендуемая замена
Replacement | UC382TDKTTT-ADJ |
Replacement Code | S |
Accuracy(%) | 1.3 |
Additional Features | Overcurrent Protection Reverse Current Protection Thermal Shutdown |
Approx. Price (US$) | 2.78 | 1ku |
Fixed Output Options(V) | 1.5 2.1 2.5 |
Iout(Max)(A) | 3 |
Iq(Typ)(mA) | 30 |
Operating Temperature Range(C) | -40 to 100 0 to 100 0 to 70 |
Output Capacitor Type | Non-Ceramic |
Output Options | Adjustable Output Fixed Output |
PSRR @ 100KHz(dB) | 38 |
Package Group | DDPAK/TO-263 |
Package Size: mm2:W x L (PKG) | See datasheet (TO-220) |
Rating | Catalog |
Regulated Outputs(#) | 1 |
Vdo(Typ)(mV) | 350 |
Vin(Max)(V) | 7.5 |
Vin(Min)(V) | 1.7 |
Vout(Max)(V) | 6 |
Vout(Min)(V) | 1.2 |
RoHS | Не совместим |
- Evaluation Modules & Boards: TPS72518EVM-207
TPS72518 Evaluation Module
- High Current LDO Linear Reglators (UCCx81-ADJ, UCx82-ADJ, UCCx83-ADJ, UCx85-ADPDF, 56 Кб, Файл опубликован: 7 май 2002
This application provides an overview of the UCCx81-ADJ, UCCx82-ADJ, UCCx83-ADJ, UCCx84-ADJ, and UCcx85-ADJ devices.
Серия: UC382 (16)
UC382TDADJ, UC382TD ADJ
