Datasheet Texas Instruments TPS25940ARVCR — Даташит
| Серия | TPS25940 |
| Модель | TPS25940ARVCR |
18V, 5A, 42mО© eFuse With Integrated Reverse Current Protection and DevSleep Support 20-WQFN -40 to 85
TPS25940x 2.7 – 18V eFuse with True Reverse Blocking and DevSleep Support for SSDs datasheet
PDF, 2.8 Мб, Версия: A, Файл опубликован: 26 мар 2015
Купить TPS25940ARVCR на РадиоЛоцман.Цены — от 27 до 282 ₽35 предложений от 14 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Устройства горячей замены | |||
| TPS25940ARVCR Texas Instruments | 47 ₽ | ||
| TPS25940ARVCR Texas Instruments | 99 ₽ | ||
| TPS25940ARVCR Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | RVC |
| Industry STD Term | WQFN |
| JEDEC Code | R-PQFP-N |
| Package QTY | 3000 |
| Carrier | LARGE T&R |
| Маркировка | 25940A |
| Width (мм) | 4 |
| Length (мм) | 3 |
| Thickness (мм) | .75 |
| Pitch (мм) | .5 |
| Max Height (мм) | .8 |
| Mechanical Data | Скачать |
- Evaluation Modules & Boards: TPS25940EVM-635
TPS25940x Evaluation Module
- Charging Super Capacitor With eFusePDF, 682 Кб, Файл опубликован: 8 авг 2017
Backup power management solutions are typically used in end equipment, such as solid state drives (SSDs), storage systems, data concentrators, and smart meters, where an unexpected power disruption can cause malfunction or data loss. Super capacitors or large hold-up capacitors are used as storage elements to provide enough backup power to maintain data communication prior to the whole system ’s s
Серия: TPS25940 (5)
- TPS25940ARVCR TPS25940ARVCT TPS25940LRVCR TPS25940LRVCT TPS25940XEVM-635
- Semiconductors > Power Management > Protection, Monitoring and Hot Swap > eFuses (Integrated FET)
