Datasheet Texas Instruments LM334SMX — Даташит
СерияLM334
МодельLM334SMX
3-контактный регулируемый источник тока 8-SOIC от 0 до 70
LM134/LM234/LM334 3-Terminal Adjustable Current Sources datasheet
PDF, 1.4 Мб, Версия: E, Файл опубликован: 20 июн 2013
Package TypeD
Package QTY2500
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Рекомендуемая замена
ReplacementLM334SMX/NOPB
Replacement CodeS
Initial Accuracy(Max)6 %
Iout/Iz(Max)0.01 мА
Vin(Max)40 В
Vin(Min)0.8 В
RoHSSee ti.com
  • AN-240 Wide-Range Current-to-Frequency Converters (Rev. B)
    PDF, 302 Кб, Версия: B, Файл опубликован: 29 апр 2013
    This application report discusses a wide-range current-to-frequency converters.
  • AN-C V/F Converter ICs Handle Frequency-to-Voltage Needs (Rev. B)
    PDF, 371 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Simplify your frequency-to-voltage (F/V) converter designs with versatile V/F ICs. Starting with a basicconverter circuit you can modify it to meet almost any application requirement. You can spare yourselfsome hard labor when designing F/V converters by using a voltage-to-frequency (V/F) IC in your designs.These ICs form the basis of a series of accurate yet economical F/V converters sui
  • AN-272 Op Amp Booster Designs (Rev. B)
    PDF, 959 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes the output booster or post amplifier designs required to achieveneeded voltage or current gain in applications that require substantially greater output voltage swing orcurrent (or both) than IC amplifiers can deliver.
  • Applying a New Precision Op Amp
    PDF, 421 Кб, Файл опубликован: 4 окт 2004
  • AN-256 Circuitry for Inexpensive Relative Humidity Measurement (Rev. B)
    PDF, 262 Кб, Версия: B, Файл опубликован: 6 май 2013
    Of all common environmental parameters humidity is perhaps the least understood and most difficult tomeasure. The most common electronic humidity detection methods albeit highly accurate are not obviousand tend to be expensive and complex (See Box). Accurate humidity measurement is vital to a number ofdiverse areas including food processing paper and lumber production pollution monitor
  • TO-92 Packing Options / Ordering Instructions (Rev. A)
    PDF, 287 Кб, Версия: A, Файл опубликован: 23 июн 2010
  • Semiconductors > Power Management > Voltage Reference > Current Reference
На английском языке: Datasheet Texas Instruments LM334SMX
