Datasheet Texas Instruments TMP300AIDCKR — Даташит
СерияTMP300
МодельTMP300AIDCKR
Программируемый резистором переключатель температуры до 18 В и датчик аналогового выхода 6-SC70 от -40 до 125
TMP300 1.8V, Resistor-Programmable Temperature Switch and Analog Out Temperature Sensor in SC70 datasheet
PDF, 956 Кб, Версия: D, Файл опубликован: 15 янв 2016
Pin6
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY3000
МаркировкаBPN
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
Рекомендуемая замена
ReplacementTMP300BIDCKR
Replacement CodeQ
# Comparators1
Accuracy Over Temp Range(Max)2 C
InterfaceAnalog Output,Switch
Тип выходаOpen Drain
Package GroupSC70
Package Size: mm2:W x L6SC70: 4 mm2: 2.1 x 2(SC70) PKG
Sensor Gain10 mV/Deg C
SetPoint TypeResistor Programmable
SetPoint Value-40 to 125 deg C
Special FeaturesHysteresis (5В°C or 10В°C),Pin-Selectable Hysteresis,Temperature Sensor and Switch
Supply Current(Typ)110 uA
Supply Voltage(Max)18 В
Supply Voltage(Min)1.8 В
  • Power Ref Design for TMS320C6472, 12-Vin Digital Pwr Cntrlrs, and LDOs (Rev. A)
    PDF, 559 Кб, Версия: A, Файл опубликован: 24 май 2010
    This design was created to help those wanting to design a TMS320C6472 digital signal processor into a system using a nominal input of 12 V, having a highly flexible power design, and the ability to monitor temperature as well as dynamically monitoring and controlling voltage and current.
  • Pwr Ref Design f/'C6472 12-Vin Digital Pwr Controllers and LDOs
    PDF, 558 Кб, Файл опубликован: 28 апр 2010
    This design was created to help designers wishing to design up to eight TMS320C6472 Digital Signal Processors into a system using a nominal input voltage of 12 V, having a highly flexible power design, the ability to monitor temperature, and dynamically monitor and control voltage and current.
  • Semiconductors > Sensing Products > Temperature Sensors > Temperature Switches / Thermostats
На английском языке: Datasheet Texas Instruments TMP300AIDCKR
