Datasheet Texas Instruments LMH6622MMX/NOPB — Даташит
СерияLMH6622
МодельLMH6622MMX/NOPB
Двойные широкополосные малошумящие операционные усилители 160 МГц 8-VSSOP от -40 до 85
LMH6622 Dual Wideband, Low Noise, 160 MHz, Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 25 июл 2014
Package TypeDGK
Industry STD TermVSSOP
Package QTY3500
МаркировкаA80A
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
2nd Harmonic90 dBc
3rd Harmonic100 dBc
@ MHz1
Acl, min spec gain2 V/V
Additional FeaturesDecompensated
АрхитектураBipolar,Voltage FB
BW @ Acl160 МГц
CMRR(Min)80 дБ
CMRR(Typ)100 дБ
GBW(Typ)320 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)6 мА
Iq per channel(Typ)4.3 мА
Количество каналов2
Offset Drift(Typ)2.5 uV/C
Output Current(Typ)90 мА
Package GroupVSSOP
Package Size: mm2:W x L8VSSOP: 15 mm2: 4.9 x 3(VSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)80 V/us
Total Supply Voltage(Max)12 +5V=5, +/-5V=10
Total Supply Voltage(Min)5 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.6 нВ/rtГц
Vn at Flatband(Typ)1.6 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)1.2 мВ
  • Evaluation Modules & Boards: LMH730123
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin MSOP Package
  • Evaluation Modules & Boards: LMH730036
    Evaluation Board for High-Speed Dual Op Amp in the 8-Pin SOIC Package
  • Transimpedance Amplifiers (TIA): Choosing the Best Amplifier for the job (Rev. A)
    PDF, 153 Кб, Версия: A, Файл опубликован: 16 май 2017
    This application note is intended as a guide for the designer looking to amplify the small signal from a photodiode or avalanche diode so that it would be large enough for further processing (e.g. data acquisition) or to trigger some other event in a system. The challenge in doing so, as always, is to not degrade the signal such that it becomes indistinguishable from random noi
На английском языке: Datasheet Texas Instruments LMH6622MMX/NOPB
