Datasheet Texas Instruments SN74LVC04D — Даташит
| Серия | SN74LVC04 |
| Модель | SN74LVC04D |
Шестигранный инвертор 14-SOIC от -40 до 85
Datasheet
HEX INVERTERS | |||
| SN74LVC04D Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 14 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Width (мм) | 3.91 |
| Length (мм) | 8.65 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC04 (4)
- SN74LVC04D SN74LVC04DBLE SN74LVC04DR SN74LVC04PWLE
- Semiconductors > Logic > Buffer/Driver/Transceiver > Inverting Buffer/Driver
