Datasheet Texas Instruments SN74AHCT123AD — Даташит
СерияSN74AHCT123A
МодельSN74AHCT123AD
Двойные моностабильные мультивибраторы с перезапуском 16-SOIC от -40 до 85
SN54AHCT123A, SN74AHCT123A datasheet
PDF, 931 Кб, Версия: G, Файл опубликован: 2 апр 2003
Pin16
Package TypeD
Package QTY40
МаркировкаAHCT123A
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
Bits2
F @ Nom Voltage(Max)110 Mhz
ICC @ Nom Voltage(Max)0.975 мА
Output Drive (IOL/IOH)(Max)8/-8 мА
Schmitt TriggerNo
Technology FamilyAHCT
VCC(Max)5.5 В
VCC(Min)2 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)17 нс
  • Designing With the SN74AHC123A and SN74AHCT123A
    PDF, 85 Кб, Файл опубликован: 1 окт 1999
    This application report is designed to answer any questions that the user may have on the operation of the SN74AHC/AHCT123A. It also covers the most frequently asked questions and includes detailed instructions on how to calculate the external components required to make the device function correctly. Several circuits using this device also are included to show the versatility of operation
  • Designing with the SN74LVC1G123 Monostable Multivibrator
    PDF, 158 Кб, Файл опубликован: 14 июл 2015
  • Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)
    PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
    The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
  • Semiconductors > Logic > Specialty Logic > Monostable Multivibrator
На английском языке: Datasheet Texas Instruments SN74AHCT123AD
