Datasheet Texas Instruments LP2951-33QDRGRQ1 — Даташит
Серия | LP2951-Q1 |
Модель | LP2951-33QDRGRQ1 |
Автомобильный LDO с одним выходом, 100 мА, фиксированный, широкий диапазон напряжения 8-SON от -40 до 125
LP2951-xx-Q1 Adjustable Micropower Voltage Regulators With Shutdown datasheet
PDF, 3.5 Мб, Версия: E, Файл опубликован: 5 ноя 2014
![]() 42 предложений от 17 поставщиков Чип стабилизации напряжения, TEXAS INSTRUMENTS LP2951-33QDRGRQ1 Fixed LDO Voltage Regulator, 2V to 30V, 380mV Dropout, 3.3Vout, 100mAout, SON-8 | |||
LP2951-33QDRGRQ1 Texas Instruments | от 9.81 ₽ | ||
LP2951-33QDRGRQ1 Texas Instruments | 63 ₽ | ||
LP2951-33QDRGRQ1 Texas Instruments | от 75 ₽ | ||
LP2951-33QDRGRQ1 Texas Instruments | по запросу |
Pin | 8 |
Package Type | DRG |
Industry STD Term | WSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | RACQ |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .73 |
Pitch (мм) | .5 |
Max Height (мм) | .8 |
Mechanical Data | Скачать |
Точность | 3 % |
Fixed Output Options | 3.3,5 В |
Iout(Max) | 0.1 A |
Iq(Typ) | 0.075 мА |
Output Capacitor Type | Ceramic |
Output Options | Fixed Output |
PSRR @ 100KHz | 54 дБ |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Rating | Automotive |
Regulated Outputs | 1 |
Special Features | Enable,Power Good |
Thermal Resistance ОёJA | 56 В°C/W |
Vdo(Typ) | 380 мВ |
Vin(Max) | 30 В |
Vin(Min) | 2 В |
Vout(Max) | 5 В |
Vout(Min) | 3.3 В |
- Designing Overcurrent protection for TPL7407L Peripheral DriverPDF, 177 Кб, Файл опубликован: 5 ноя 2014
Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
Серия: LP2951-Q1 (3)
- LP2951-33QDRGRQ1 LP2951-50QDRGRQ1 LP2951-50QDRQ1
LP295133QDRGRQ1, LP2951 33QDRGRQ1
