Клеммники KEEN SIDE
Datasheet Texas Instruments LM3421MH/NOPB — Даташит
СерияLM3421
МодельLM3421MH/NOPB
N-канальные контроллеры для драйверов светодиодов постоянного тока 16-HTSSOP от -40 до 125
LM342x/-Q1 N-Channel Controllers for Constant-Current LED Drivers datasheet
PDF, 2.5 Мб, Версия: F, Файл опубликован: 4 ноя 2014
Pin1616
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9292
CarrierTUBETUBE
МаркировкаLM3421MH
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Dimming MethodAnalog,PWM
Входное напряжениеDC/DC Type
Iout(Max)5 A
Iq(Typ)2 мА
Package GroupHTSSOP
Package Size: mm2:W x L16HTSSOP: 22 mm2: 4.4 x 5(HTSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Thermal Shutdown
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)100 kHz
TopologyBoost,Boost Controller,Buck-Boost,Sepic
ТипController,Inductive
Vin(Max)75 В
Vin(Min)4.5 В
Vout(Max)72 В
Vout(Min)3 В
Vref1.24 В
  • Evaluation Modules & Boards: LM3423BS2LYEV
    Boost 2 Layer LED Driver Evaluation Board
  • Evaluation Modules & Boards: LM3421-SEPICEV
    SEPIC LED Driver Evaluation Board for Automotive Applications
  • Evaluation Modules & Boards: LM3423BBLSCSEV
    LM3423 Buck-Boost 2-Layer Low Side Current Sense Evaluation Board
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3421 (2)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3421MH/NOPB
