Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI SN74LVC162244AZQLR — Даташит
СерияSN74LVC162244A
МодельSN74LVC162244AZQLR
Datasheet Texas Instruments SN74LVC162244AZQLR
16-битный буфер/драйвер с выходами с 3 состояниями 56 BGA MICROSTAR JUNIOR от -40 до 85
SN74LVC162244A 16-Bit Buffer/Driver with 3-State Outputs datasheet
PDF, 906 Кб, Версия: B, Файл опубликован: 5 июн 2014
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
На английском языке: Datasheet Texas Instruments SN74LVC162244AZQLR
Политика конфиденциальности
