Datasheet ТI CD54HC4020F — Даташит
СерияCD54HC4020
МодельCD54HC4020F
Datasheet Texas Instruments CD54HC4020F
Высокоскоростная логика КМОП, 14-ступенчатый двоичный счетчик, 16-CDIP, от -55 до 125
CD54HC4020, CD74HC4020, CD54HCT4020, CD74HCT4020 datasheet
PDF, 455 Кб, Версия: C, Файл опубликован: 16 окт 2003
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC4020 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC4020F
Политика конфиденциальности
