Datasheet Texas Instruments OPA552UAG4 — Даташит
| Серия | OPA552 |
| Модель | OPA552UAG4 |
Высоковольтные сильноточные операционные усилители 8-SOIC
OPA55x High-Voltage, High-Current Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 7 янв 2016
Купить OPA552UAG4 на РадиоЛоцман.Цены — от 87 до 1 741 ₽9 предложений от 9 поставщиков Микросхема Буферный усилитель, OP Amp Single GP ±30V/60V 8Pin SOIC Tube | |||
| OPA552UAG4 Texas Instruments | 87 ₽ | ||
| OPA552UAG4 Texas Instruments | 274 ₽ | ||
| OPA552UAG4 Texas Instruments | по запросу | ||
| Pin | 8 | 8 |
| Package Type | D | D |
| Industry STD Term | SOIC | SOIC |
| JEDEC Code | R-PDSO-G | R-PDSO-G |
| Package QTY | 75 | 75 |
| Carrier | TUBE | TUBE |
| Маркировка | 552UA | OPA |
| Width (мм) | 3.91 | 3.91 |
| Length (мм) | 4.9 | 4.9 |
| Thickness (мм) | 1.58 | 1.58 |
| Pitch (мм) | 1.27 | 1.27 |
| Max Height (мм) | 1.75 | 1.75 |
| Additional Features | Decompensated |
| Архитектура | FET |
| CMRR(Min) | 92 дБ |
| CMRR(Typ) | 102 дБ |
| GBW(Typ) | 12 МГц |
| Input Bias Current(Max) | 100 pA |
| Iq per channel(Max) | 8.5 мА |
| Iq per channel(Typ) | 7 мА |
| Количество каналов | 1 |
| Offset Drift(Typ) | 7 uV/C |
| Output Current(Typ) | 380 мА |
| Package Group | SOIC |
| Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
| Rail-to-Rail | No |
| Rating | Catalog |
| Slew Rate(Typ) | 24 V/us |
| Total Supply Voltage(Max) | 60 +5V=5, +/-5V=10 |
| Total Supply Voltage(Min) | 8 +5V=5, +/-5V=10 |
| Vos (Offset Voltage @ 25C)(Max) | 3 мВ |
- Evaluation Modules & Boards: OPAMPEVM
Universal Operational Amplifier Evaluation Module
- MTTF, Failrate, Reliability, and Life TestingPDF, 51 Кб, Файл опубликован: 4 окт 2000
At Burr-Brown, we characterize and qualify the reliability of our devices through high temperature life testing. The results of this testing are quantified with such values as MTTF and failure rate. This information can be very valuable when used for comparative purposes or applied to reliablility calculations. However, this information loses its worth if it is not precisely understood and appropr - Optoelectronics Circuit CollectionPDF, 261 Кб, Файл опубликован: 11 июн 2001
This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
Серия: OPA552 (10)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
