Datasheet Texas Instruments BQ25871YFFT — Даташит
СерияBQ25871
МодельBQ25871YFFT
Зарядное устройство 1S, 7 А, со встроенным АЦП 42-DSBGA от -40 до 85
bq25871 14-V, 7-A, Battery Switch Charger with Integrated 10-bit ADC datasheet
PDF, 1.2 Мб, Файл опубликован: 1 сен 2016
Pin42
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY250
CarrierSMALL T&R
МаркировкаBQ25871
Width (мм)2.4
Length (мм)2.8
Thickness (мм).415
Pitch (мм).4
Max Height (мм).625
Absolute Vin (safety rating)(Max)(22 В
Battery Charge Voltage(Max)4.975 В
Battery Charge Voltage(Min)4.2 В
Cell ChemistryLi-Ion/Li-Polymer
Charge Current(Max)7 A
Control InterfaceI2C
Control TopologyFlash Charger
Number of Series Cells1
Operating Vin(Max)6 В
Operating Vin(Min)2.8 В
Package GroupDSBGA
Special FeaturesIntegrated FET,Over Voltage Protection,Standard BAT Temp Monitoring,Temp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: BQ25871EVM-813
    BQ25871 Complete Charger Evaluation Module
  • Flash Battery Charging Pushes the Boundary of Charging Current
    PDF, 109 Кб, Файл опубликован: 15 мар 2017
    Withthe developmentof batterytechnologyand the requirementsfor electronicproductswith a longerrunningtime,batterycapacitycontinuesto increase.To maintainthe existingchargingtime with increasedbatterycapacity,fast-chargingtechnologyis oneof the preferredfeaturesfor smartphones.Existingchargersare dividedinto linearchargerand switchingc
Серия: BQ25871 (2)
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ25871YFFT
