Datasheet Texas Instruments LM3152MH-3.3/NOPB — Даташит
СерияLM3152
МодельLM3152MH-3.3/NOPB
КОНТРОЛЛЕР SIMPLE SWITCHER®, синхронное понижающее напряжение 42 В, 14-HTSSOP от -40 до 125
LM3151/52/53 SIMPLE SWITCHER CONTROLLER, High Input Voltage Sync Step-Down datasheet
PDF, 1.1 Мб, Версия: G, Файл опубликован: 4 мар 2011
Pin1414
Package TypePWPPWP
Industry STD TermHTSSOPHTSSOP
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9494
CarrierTUBETUBE
Маркировка-3.3LM3152
Width (мм)4.44.4
Length (мм)55
Thickness (мм)11
Pitch (мм).65.65
Max Height (мм)1.21.2
Control ModeCOT with emulated ripple
Duty Cycle(Max)81 %
Iout(Max)12 A
Iq(Typ)3.6 мА
Number of Phases1
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Synchronous Rectification,Tracking
Switching Frequency(Max)500 kHz
Switching Frequency(Min)500 kHz
ТипController
Vin(Max)33 В
Vin(Min)6 В
Vout(Max)3.3 В
Vout(Min)3.3 В
  • Evaluation Modules & Boards: LM3152-3.3DEMO
    LM3152 - RD-164 - Demonstration Board
  • Controlling Output Ripple & Achiev ESR Indep Constant On-Time Reg Designs (Rev. A)
    PDF, 178 Кб, Версия: A, Файл опубликован: 23 апр 2013
    Of all the voltage regulator control strategies ever devised, the hysteretic regulator is probably about thesimplest. This control methodology simply turns a switch on when the output voltage is below a referenceand turns the switch off when the output rises to a slightly higher reference. The output ripple is thereforea direct function of the difference between the upper and lower reference
Серия: LM3152 (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
LM3152MH3.3/NOPB, LM3152MH 3.3/NOPB
На английском языке: Datasheet Texas Instruments LM3152MH-3.3/NOPB
