Datasheet Texas Instruments TPA2038D1YFFR — Даташит
СерияTPA2038D1
МодельTPA2038D1YFFR
Переменное усиление, 3,2 Вт, моно, класс D, со встроенным шумозащитным фильтром ЦАП 9-DSBGA от -40 до 85
3.2W Mono Class-D with Selectable Gain. datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 19 июн 2012
АЦП азиатских производителей
Pin9
Package TypeYFF
Industry STD TermDSBGA
JEDEC CodeS-XBGA-N
Package QTY3000
МаркировкаQWK
Width (мм)1.4
Length (мм)1.4
Thickness (мм).425
Pitch (мм).4
Max Height (мм).625
Analog Supply (V)2.5 Max
АрхитектураClass D
Audio Input TypeAnalog Input
Control InterfaceGPIO
Iq per channel(Typ)1.8 мА
Iq(Max)2.5 мА
Iq(Typ)1.8 мА
Load(Min)4 ohms
Выходная мощность3.2 W
PSRR86 дБ
Package GroupDSBGA
Pin/Package9DSBGA
Shutdown Current (ISD)0.5 uA
Speaker ChannelsMono Max
THD + N @ 1 kHz0.12 %
  • Evaluation Modules & Boards: TPA2038D1YFFEVM
    TPA2038D1 Evaluation Module
  • AN-1737 Managing EMI in Class D Audio Applications (Rev. A)
    PDF, 140 Кб, Версия: A, Файл опубликован: 1 май 2013
    Electromagnetic interference (EMI) is an unwanted disturbance caused in an electrical circuit byelectromagnetic radiation emitted from an external source. The disturbance may interrupt, obstruct, orotherwise degrade the effective performance of the circuit.
  • AN-1849 An Audio Amplifier Power Supply Design (Rev. B)
    PDF, 1.9 Мб, Версия: B, Файл опубликован: 1 май 2013
    This application report provides design information for a power supply for use with our newest offering of high-performance, ultra high-fidelity audio amplifier input stage ICs.
  • Guidelines for Measuring Audio Power Amplifier Performance
    PDF, 765 Кб, Файл опубликован: 30 окт 2001
    This application note provides guidelines for measuring the date sheet parameters of Texas Instruments audio power amplifiers (APAs) using prefabricated evaluation modules (EVMs). The primary equipment used for the measurements consists of the System Two audio measurement system by Audio Precision , a digital multimeter (DMM), and a dc power supply.
Серия: TPA2038D1 (2)
  • Semiconductors > Audio > Low-Power Audio Amplifiers (<10W) > Speaker Amplifier Class AB/Class D
На английском языке: Datasheet Texas Instruments TPA2038D1YFFR
