Datasheet Texas Instruments TS3USB30RSWR — Даташит
Серия | TS3USB30 |
Модель | TS3USB30RSWR |
Высокоскоростной USB 2.0 (480 Мбит/с), переключатель мультиплексор/демультиплексор 1:2 с одинарным включением 10-UQFN от -40 до 85
High-Speed USB 2.0 1:2 Multiplexer/Demultiplexer Switch With Single Enable* datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 14 авг 2015
Pin | 10 | 10 |
Package Type | RSW | RSW |
Industry STD Term | UQFN | UQFN |
JEDEC Code | R-PQFP-N | R-PQFP-N |
Package QTY | 3000 | 3000 |
Carrier | LARGE T&R | LARGE T&R |
Маркировка | L67 | L6O |
Width (мм) | 1.4 | 1.4 |
Length (мм) | 1.8 | 1.8 |
Thickness (мм) | .45 | .45 |
Pitch (мм) | .4 | .4 |
Max Height (мм) | .55 | .55 |
Additional Features | Logic Controlled (Output Enabled) |
Полоса частот | 955 МГц |
Configuration | 2:1 SPDT |
Crosstalk(Typ) | -56 дБ |
ESD Charged Device Model(Typ) | 1 kV |
ESD HBM(Typ) | 6 kV |
ICC(Max) | 1 uA |
Input/Ouput Voltage(Max) | 4.3 В |
Input/Output OFF-state Capacitance(Typ) | 2 пФ |
Input/Output ON-state Capacitance(Typ) | 7 пФ |
Количество каналов | 2 |
OFF-state leakage current(Max) | 2 мкА |
Off Isolation(Typ) | -39 дБ |
Package Group | UQFN |
Package Size: mm2:W x L | 10UQFN: 3 mm2: 1.4 x 1.8(UQFN) PKG |
Propagation Delay(Typ) | 0.25 нс |
Protocols | USB/MHL |
Ron Channel Match(Max) | 0.35 Ω |
Ron(Max) | 10 Ohms |
Ron(Typ) | 6 Ohms |
Turn off Time (Disable)(Max) | 25 нс |
Turn on Time (Enable)(Max) | 30 нс |
VCC(Max) | 4.3 В |
VCC(Min) | 3 В |
- Preventing Excess Power Consumption on Analog SwitchesPDF, 238 Кб, Файл опубликован: 3 июл 2008
Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica - High-Speed Interface Layout Guidelines (Rev. G)PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
Серия: TS3USB30 (1)
- TS3USB30RSWR
- Semiconductors > Switches and Multiplexers > Protocol Specific Switches/Muxes
