Datasheet Texas Instruments TPS54615PWPG4 — Даташит
СерияTPS54615
МодельTPS54615PWPG4
Синхронный понижающий преобразователь SWIFT™ с входным напряжением от 3 В до 6 В, ток 6 А и выходным напряжением 2,5 В, 28-HTSSOP от -40 до 125
TPS5461x 3-V to 6-V Input, 6-A Output Synchronous Buck PWM Switcher With Integrated FETs (SWIFTв„ў) datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 15 янв 2015
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY50
МаркировкаTPS54615
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
  • Evaluation Modules & Boards: TPS54614EVM-183
    TPS54614 6V Input, 1.8V Output, 6A Evaluation Module
  • Evaluation Modules & Boards: XILINXPWR-082
    XILINXPWR-082 Power Management Evaluation Module for Xilinx FPGAs
  • Designing with the TPS54611 Through TPS54616 Synchronous Buck Regulators (Rev. A)
    PDF, 128 Кб, Версия: A, Файл опубликован: 7 фев 2002
    The switcher with integrated FETs (SWIFT?) TPS5461x family of internally compensated synchronous buck regulators offers a quick and easy solution to many power supply applications. These devices require a minimum of six additional components. The design procedure is simple and can be accomplished with the five basic steps outlined in this application report.
  • Optimizing the Layout of the TPS546xx for Thermal Performance (Rev. A)
    PDF, 240 Кб, Версия: A, Файл опубликован: 8 фев 2002
    This application report examines the thermal performance of different layout techniques for the TPS5461x family of 6-amp synchronous buck regulators. The TPS5461x family consists of the TPS54610, TPS54611, TPS54612, TPS54613, TPS54615, and the TPS54616. The TPS54610 has an adjustable output voltage, while the output voltages of the other devices in this family are fixed. This application note is a
  • Adjusting Vout of Internal Compensated Low Input Voltage SWIFT DC/DC Converters (Rev. A)
    PDF, 341 Кб, Версия: A, Файл опубликован: 2 ноя 2006
  • TI Power Solutions Power Up Altera FPGAs
    PDF, 167 Кб, Файл опубликован: 18 окт 2002
    Power requirements and power consumptions for Altera FPGAs including ACEX 1K APEX II Mercury and Stratix families are summarized and calculated at typical applications as a first?cut estimation for engineers designing with those multivoltage families. Design examples which cover LDOs SWIFT DC/DC controllers and power modules are demonstrated. Certain sequencing strategy is shown in each des
Серия: TPS54615 (4)
На английском языке: Datasheet Texas Instruments TPS54615PWPG4
