Datasheet Texas Instruments SNJ54CBT3383W — Даташит
СерияSN54CBT3383
МодельSNJ54CBT3383W
10-битный переключатель обмена шинами 24-CFP от -55 до 125
SNx4CBT3383 10-Bit Bus-Exchange Switch datasheet
PDF, 1.0 Мб, Версия: P, Файл опубликован: 7 янв 2016
Микросхема Логический чип, Bus Exchange Switch 1Element 5CH 24Pin CFPAK Tube
SNJ54CBT3383W
398 ₽
SNJ54CBT3383W
4 039 ₽
SNJ54CBT3383W
Pin242424
Package TypeWWW
Industry STD TermCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY111
CarrierTUBETUBETUBE
МаркировкаA5962-9668801QKSNJ54CBT3383W
Width (мм)9.099.099.09
Length (мм)14.3614.3614.36
Thickness (мм)1.721.721.72
Pitch (мм)1.271.271.27
Max Height (мм)2.292.292.29
Количество каналов10
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Ron(Max)7 Ohms
Ron(Typ)5 Ohms
Technology FamilyCBT
VCC(Max)5.5 В
VCC(Min)4.5 В
RoHSSee ti.com
  • Flexible Voltage-Level Translation With CBT Family Devices
    PDF, 40 Кб, Файл опубликован: 20 июл 1999
    Voltage translation between buses with incompatible logic levels can be accomplished using Texas Instruments (TI) translation-voltage clamps (TVC) or standard crossbar technology (CBT) devices. CBT devices in this application offer flexibility in designs, protection of circuits that are sensitive to high-state voltage-level overshoots, and cost efficiency.
  • 5-V To 3.3-V Translation With the SN74CBTD3384 (Rev. B)
    PDF, 35 Кб, Версия: B, Файл опубликован: 1 мар 1997
    The emergence of low-voltage technology required existing 5-V systems to interact with 3.3-V systems. Compatibility issues of mixed-mode operation created the need for 5-V to 3.3-V translation. Buffers and transceivers serve as effective translators. While providing additional drive, these devices also add propagation delay and require directional control. In cases where additional drive is not
  • 3.3-V to 2.5-V Translation with Texas Instruments Crossbar Technology (Rev. A)
    PDF, 32 Кб, Версия: A, Файл опубликован: 3 апр 1998
  • Semiconductors > Space & High Reliability > Logic Products > Switches and Multiplexer > Signal Switch
На английском языке: Datasheet Texas Instruments SNJ54CBT3383W
