Datasheet Texas Instruments LM2576T-3.3/LB03 — Даташит
СерияLM2576
МодельLM2576T-3.3/LB03
SIMPLE SWITCHERВ® 40V, 3A Low Component Count Step-Down Regulator 5-TO-220
LM2576xx Series SIMPLE SWITCHER 3-A Step-Down Voltage Regulator datasheet
PDF, 4.5 Мб, Версия: D, Файл опубликован: 27 май 2016
Pin55
Package TypeNDHNDH
Industry STD TermTO-220TO-220
JEDEC CodeR-MSFM-LR-MSFM-L
Маркировка-3.3 P+LM2576T
Width (мм)10.1610.16
Length (мм)14.98614.986
Thickness (мм)4.5724.572
Pitch (мм)1.7021.702
Max Height (мм)4.74.7
Рекомендуемая замена
ReplacementLM2576T-3.3/NOPB
Replacement CodeS
Approx. Price (US$)1.19 | 1ku
Control ModeVoltage Mode
Duty Cycle(Max)(%)98
Iout(Max)(A)3
Iq(Typ)(mA)5
Operating Temperature Range(C)-40 to 125
Package GroupTO-220
Regulated Outputs(#)1
Special FeaturesEnable
Switching Frequency(Max)(kHz)63
Switching Frequency(Min)(kHz)42
ТипConverter
Vin(Max)(V)40
Vin(Min)(V)4
Vout(Max)(V)37
Vout(Min)(V)3.3
RoHSНе совместим
  • Evaluation Modules & Boards: LM2576S-ADJEVM
    LM2576 Step-Down Converter Evaluation Module
  • High-Efficiency 3A Battery Chargers Use LM2576 Regulators (Rev. B)
    PDF, 187 Кб, Версия: B, Файл опубликован: 23 апр 2013
    This application report describes two LM2576-based designs that provide up to 3A of current for batterycharging.
  • AN-776 20-W SIMPLE SWITCHER Forward Converter (Rev. A)
    PDF, 593 Кб, Версия: A, Файл опубликован: 23 апр 2013
    This application note provides information about the 20-watt simple switcher forward converter.
  • Battery Charging
    PDF, 146 Кб, Файл опубликован: 21 мар 2007
  • Buck Converters Provide a Battery Charger and System Power
    PDF, 61 Кб, Файл опубликован: 21 мар 2007
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Switching Regulator Fundamentals (Rev. A)
    PDF, 324 Кб, Версия: A, Файл опубликован: 23 сен 2016
    Theswitchingregulatoris increasingin popularitybecauseit offersthe advantagesof higherpowerconversionefficiencyand increaseddesignflexibility(multipleoutputvoltagesof differentpolaritiescan begeneratedfroma singleinputvoltage).
LM2576T3.3/LB03, LM2576T 3.3/LB03
На английском языке: Datasheet Texas Instruments LM2576T-3.3/LB03
