Datasheet Texas Instruments TLV2721IDBV — Даташит
СерияTLV2721
МодельTLV2721IDBV
Одиночный операционный усилитель LinCMOS™ Rail-To-Rail с очень низким энергопотреблением 5-SOT-23
Advanced LinCMOS(TM) Rail-to-Rail Very Low-Power Single Operational Amplifiers datasheet
PDF, 710 Кб, Версия: A, Файл опубликован: 12 мар 2001
Pin5
Package TypeDBV
Industry STD TermSOT
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Additional FeaturesN/A
Approx. Price (US$)0.44 | 1ku
АрхитектураCMOS
CMRR(Min)(dB)70
CMRR(Typ)(dB)85
GBW(Typ)(MHz)0.51
Input Bias Current(Max)(pA)60
Iq per channel(Max)(mA)0.15
Iq per channel(Typ)(mA)0.11
Number of Channels(#)1
Offset Drift(Typ)(uV/C)1
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)4
Package GroupSOT-23
Package Size: mm2:W x L (PKG)5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Rail-to-RailIn to V-
Out
Slew Rate(Typ)(V/us)0.25
Total Supply Voltage(Max)(+5V=5, +/-5V=10)10
Total Supply Voltage(Min)(+5V=5, +/-5V=10)2.7
Vn at 1kHz(Typ)(nV/rtHz)19
Vos (Offset Voltage @ 25C)(Max)(mV)3
RoHSНе совместим
  • DC Parameters: Input Offset Voltage
    PDF, 295 Кб, Файл опубликован: 27 мар 2001
    The input offset voltage, VIO, is a common dc parameter in operational amplifier (op amp) specifications. This report aims to familiarize the engineer by discussing the basics and modern aspects of VIO by providing a definition and a detailed explaination of causes of VIO for BJT, BiFET, and CMOS devices. Discussion centers around measurement techniques, data sheet specifications, and the effect o
На английском языке: Datasheet Texas Instruments TLV2721IDBV
