Datasheet Texas Instruments DRV8307RHAR — Даташит
СерияDRV8307
МодельDRV8307RHAR
3-фазный контроллер BLDC и предварительный драйвер (управление ШИМ) 40-VQFN от -40 до 85
DRV8307 Brushless DC Motor Controller datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 2 фев 2016
Pin40
Package TypeRHA
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY2500
МаркировкаDRV8307
Width (мм)6
Length (мм)6
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Control I/FPWM (1x)
Current Sense Amps1
Gate Drive0.03 A
Number of Half Bridges3
Package GroupVQFN
Package Size: mm2:W x L40VQFN: 36 mm2: 6 x 6(VQFN) PKG
Vs(Max)32 В
Vs(Min)8.5 В
  • Evaluation Modules & Boards: DRV8307EVM
    DRV8307 Evaluation Module for Three-phase Brushless Motor Pre-driver
  • Hardware Design Considerations for an Electric Bicycle using BLDC Motor
    PDF, 530 Кб, Файл опубликован: 11 июн 2014
    A traditional bicycle is a two-wheel vehicle that is propelled by the rider who delivers muscle power through pedals that rotate one of the two wheels. The rider steers the front wheel to create a force that returns and maintains the vehicle center of gravity into a stable zone whenever necessary, thus keeping the bicycle upright. An electric bicycle carries batteries that deliver electric power t
  • Hardware Design Considerations for an Efficient Vacuum Cleaner using BLDC Motor (Rev. A)
    PDF, 213 Кб, Версия: A, Файл опубликован: 15 июл 2015
    A vacuum cleaner is a device that uses an air pump to create a partial vacuum to suck up dirt and dust particles from a given surface. Vacuum cleaners are used in homes as well as in industries and come with a variety of power levels, small battery-operated hand-held devices, domestic central vacuum cleaners and huge stationary industrial appliances. A universal motor is typically used as suction
  • Understanding IDRIVE and TDRIVE in TI Motor Gate Drivers (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 11 май 2016
    The motor gate driver is an integrated circuit (IC) that primarily deals with enhancing external power MOSFETs to drive an electric motor. The gate driver acts as an intermediate stage between the logic-level control inputs and the power MOSFETs. The gate driver must be flexible enough to accommodate a wide variety of external MOSFETs and external system conditions.Texas Instrument’s IDRIVE
Серия: DRV8307 (2)
  • Semiconductors > Motor Drivers > Brushless DC (BLDC) Drivers > Brushless DC Gate Drivers
На английском языке: Datasheet Texas Instruments DRV8307RHAR
