Datasheet Texas Instruments 74AC11244PWLE — Даташит
Серия74AC11244
Модель74AC11244PWLE
Восьмеричные буферы/драйверы 24-TSSOP от -40 до 85
Octal Buffer/Driver With 3-State Outputs datasheet
PDF, 788 Кб, Версия: B, Файл опубликован: 15 сен 1998
Микросхема Логический чип, Buffer/Line Driver 8CH Non-Inverting 3-ST CMOS 24Pin TSSOP T/R
74AC11244PWLE
27 ₽
74AC11244PWLE
99 ₽
Элитан
74AC11244PWLE
256 ₽
Зенер
Россия и страны ТС
74AC11244PWLE
283 ₽
Pin24
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)1.24 | 1ku
Bits(#)8
F @ Nom Voltage(Max)(Mhz)60
ICC @ Nom Voltage(Max)(mA)0.08
Тип входаCMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)-24/24
Тип выходаCMOS
Package GroupTSSOP
Schmitt TriggerNo
Technology FamilyAC
VCC(Max)(V)5.5
VCC(Min)(V)3
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)7.3
RoHSНе совместим
  • Live Insertion
  • Introduction to Logic
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
На английском языке: Datasheet Texas Instruments 74AC11244PWLE
