Datasheet Texas Instruments TPS40192DRCTG4 — Даташит
СерияTPS40192
МодельTPS40192DRCTG4
Входное напряжение от 4,5 до 18 В, малое количество контактов, синхронный понижающий контроллер с Power Good 10-VSON от -40 до 85
TPS4019x 4.5-V to 18-V Input, 10-Pin, Synchronous Buck Controller With Power Good datasheet
PDF, 2.6 Мб, Версия: F, Файл опубликован: 11 ноя 2016
Pin10
Package TypeDRC
Industry STD TermVSON
JEDEC CodeS-PDSO-N
Package QTY250
CarrierSMALL T&R
Маркировка0192
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Duty Cycle(Max)85 %
Iout(Max)15 A
Iq(Typ)2.5 мА
Number of Phases1
Package GroupVSON
Regulated Outputs1
Special FeaturesEnable,Pre-Bias Start-Up,Synchronous Rectification
Switching Frequency(Max)600 kHz
Switching Frequency(Min)600 kHz
ТипController
Vin(Max)18 В
Vin(Min)4.5 В
Vout(Max)14.4 В
Vout(Min)0.591 В
  • Evaluation Modules & Boards: TPS40192EVM-001
    TPS40192 14V Input, 1.8V Output, 10A Evaluation Module
  • Evaluation Modules & Boards: TPS40192EVM-525
    10A, 12V Input, 1.8V Output Synchronous Buck Converter using the TPS40192 and NexFETВ™ MOSFETs
  • Evaluation Modules & Boards: TPS40193EVM-001
    TPS40193 12V Input, 1.8V Output, 10A Evaluation Module
  • TMS320C6472 5V Input Pwr Design, Integrated FET DC/DC Converters and Controllers
    PDF, 452 Кб, Файл опубликован: 26 мар 2010
    This reference design is intended for designers who wish to design up to eight TMS320C6472 Digital Signal Processors into a system using a nominal input voltage of 5 V, with a flexible design using external FETs, and low-dropout regulators for the low-power rails.
  • Enabling Multiple TPS4019x Devices
    PDF, 72 Кб, Файл опубликован: 29 мар 2012
  • Not All Jitter Is Created Equal (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 июл 2015
    This application report offers a tutorial discussion on jitter in switching DC-DC converters. Not all power supply designs are equally susceptible to jitter, nor are they equally affected by jitter. Modes of switching jitter are defined and explained for several popular control architectures, which are then analyzed for sources of jitter. An example contrasting the amount of jitter and effect on o
  • 'C6472 12Vin Flexible Pwr Design Using DCDC Controllers and LDOs (8x C6472)
    PDF, 441 Кб, Файл опубликован: 26 мар 2010
    This reference design is intended for designers who wish to design up to eight TMS320C6472 Digital Signal Processors into a system using a nominal input voltage of 12 V, external FETs for design flexibility, and low-dropout regulators for the low-power rails.
  • Power Reference Design for the 'C6472 12V DCDC Controllers and LDOs
    PDF, 245 Кб, Файл опубликован: 26 мар 2010
    This reference design is intended for designers who wish to design a TMS320C6472 Digital Signal Processor into a system using a nominal input voltage of 12 V external FETs for design flexibility and low-dropout regulators for the low-power rails.
  • 5Vin DM643x Power using DC/DC Controllers and LDO
    PDF, 741 Кб, Файл опубликован: 9 окт 2008
  • 5Vin C642x Power using DC/DC Controllers and LDO
Серия: TPS40192 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Controller (External Switch)
На английском языке: Datasheet Texas Instruments TPS40192DRCTG4
