Datasheet Texas Instruments TL750M08CKTPRG3 — Даташит
| Серия | TL750M08 |
| Модель | TL750M08CKTPRG3 |
TL750M Series Low-Dropout Voltage Regulator (Rev. N)
PDF, 1.2 Мб, Версия: N, Файл опубликован: 1 янв 2019
7 предложений от 7 поставщиков IC REG LIN 8V 750MA 2POWERFLEX. Linear Voltage Regulator IC 1 Output 750mA 2-PowerFLEXTM. PMIC - Voltage Regulators - Linear... | |||
| TL750M08CKTPRG3 Texas Instruments | по запросу | ||
| Статус продукта | Снят с производства (Производитель прекратил производство прибора) |
| Pin | 2 |
| Package Type | KTP |
| Industry STD Term | PFM |
| JEDEC Code | R-PSFM-G |
| Width (мм) | 6.15 |
| Length (мм) | 6.04 |
| Thickness (мм) | 1.91 |
| Pitch (мм) | 4.57 |
| Max Height (мм) | 2.03 |
| Mechanical Data | Скачать |
| Accuracy(%) | 1 |
| Additional Features | Overcurrent Protection Thermal Shutdown |
| Approx. Price (US$) | 0.42 | 1ku |
| Fixed Output Options(V) | 8 |
| Iout(Max)(A) | 0.75 |
| Iq(Typ)(mA) | 5 |
| Noise(uVrms) | 500 |
| Operating Temperature Range(C) | 0 to 125 |
| Output Capacitor Type | Non-Ceramic |
| Output Options | Fixed Output |
| Package Group | TO-220 TO-252 |
| Package Size: mm2:W x L (PKG) | See datasheet (PFM) See datasheet (TO-220) |
| Powered Load | FPGA Microcontroller Microprocessor |
| Rating | Catalog |
| Regulated Outputs(#) | 1 |
| Vdo(Typ)(mV) | 600 |
| Vin(Max)(V) | 26 |
| Vin(Min)(V) | 9 |
| Vout(Max)(V) | 8 |
| Vout(Min)(V) | 8 |
| RoHS | Не совместим |
| Бессвинцовая технология (Pb Free) | Нет |
- Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TL750M08 (2)
- TL750M08CKCE3 TL750M08CKTPRG3
Купить TL750M08CKTPRG3 на РадиоЛоцман.Цены
