Datasheet Texas Instruments ADS1213UG4 — Даташит
| Серия | ADS1213 |
| Модель | ADS1213UG4 |
22-битный аналого-цифровой преобразователь 24-SOIC от -40 до 85
ADS1212, ADS1213: 22-Bit Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 18 фев 2004
Купить ADS1213UG4 на РадиоЛоцман.Цены — от 531 до 2 095 ₽9 предложений от 9 поставщиков Микросхема Преобразователь AD, Single ADC Delta-Sigma 6.25KSPS 22Bit Serial 24Pin SOIC Tube | |||
| ADS1213UG4 Texas Instruments | 531 ₽ | ||
| ADS1213UG4 Texas Instruments | 1 071 ₽ | ||
| ADS1213UG4 | по запросу | ||
| ADS1213UG4 Texas Instruments | по запросу | ||
| Pin | 24 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 25 |
| Carrier | TUBE |
| Маркировка | ADS1213U |
| Width (мм) | 7.5 |
| Length (мм) | 15.4 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
- Calibration Routines and Register Value Generation for the ADS121x SeriesPDF, 298 Кб, Файл опубликован: 19 июн 2003
In order to achieve the best possible performance, offset and gain can be often be calibrated in high-resolution analog-to-digital converters (ADCs). Changes in temperature, PGA gain, power supply voltage, or most importantly, decimation ratio can influence the accuracy of measurement. This application note explains how the calibration routines work and how to generate values for the full-scale re - Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma ConvertersPDF, 105 Кб, Файл опубликован: 27 сен 2000
Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems. - Inputs Currents for High-Resolution ADCsPDF, 127 Кб, Файл опубликован: 6 мар 2003
- Coding Schemes Used with Data Converters (Rev. A)PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
- Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference. - Principles of Data Acquisition and Conversion (Rev. A)PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1213 (7)
- ADS1213E ADS1213E/1K ADS1213E/1KG4 ADS1213EG4 ADS1213U ADS1213U/1K ADS1213UG4
