Линейка продуктов KEEN SIDE
Datasheet Texas Instruments THS6052IDG4 — Даташит
СерияTHS6052
МодельTHS6052IDG4
175 мА, +/-12 В Драйвер линии ADSL CPE 8-SOIC от -40 до 85
175 mA +/-12 V ADSL CPE Line Drivers datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 13 дек 2001
Package TypeD
Package QTY75
Маркировка6052I
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl170 МГц
CMRR(Min)59 дБ
CMRR(Typ)66 дБ
GBW(Typ)170 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)7 мА
Iq per channel(Typ)5.2 мА
Количество каналов2
Offset Drift(Typ)30 uV/C
Output Current(Typ)175 мА
Rail-to-RailNo
Slew Rate(Typ)1700 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at Flatband(Typ)2.1 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)10 мВ
  • Evaluation Modules & Boards: THS6052EVM
    THS6052 Evaluation Module
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6052IDG4
