Datasheet ТI TPA3255DDV — Даташит
| Серия | TPA3255 |
| Модель | TPA3255DDV |
315 Вт стерео / 600 Вт моно Ultra-HD, аналоговый входной усилитель класса D 44-HTSSOP от 0 до 70
TPA3255 315-W Stereo, 600-W Mono PurePathв„ў Ultra-HD Analog-Input datasheet
PDF, 1.6 Мб, Версия: A, Файл опубликован: 4 окт 2016
- TPA324x and TPA325x Post-Filter FeedbackTSP, Файл опубликован: 14 сен 2017
- TPA3251 and TPA3255 Post-Filter Feedback (PFFB)PDF, 567 Кб, Файл опубликован: 28 июл 2016
The TPA32xx Class-D audio amplifier family delivers tremendously high audio performance with less than 0.01% THD+N to clipping. The extremely high level of audio performance makes this device an ideal candidate for today’s high resolution and high fidelity audio applications where previously, only Class-AB amplifiers could deliver the performance.Since the TPA32xx family is an analog input close - TPA32xx Analog Input Grounding for Single Ended InputsPDF, 79 Кб, Файл опубликован: 26 авг 2016
- Multi-Device Configuration for TPA32xx AmplifiersPDF, 102 Кб, Файл опубликован: 27 сен 2017
The TPA324x and TPA325x family of parts (TPA3244, TPA3245, TPA3250, TPA3251, and TPA3255)comes equipped with functionality to simplify systems with multiple Class-D amplifiers. Class-D amplifiersuse pulse-width modulation (PWM) switching (450 kHz – 600 kHz), which are discrete packets of energy,to deliver large amounts of power with very high efficiency. However, issues can arise if multiple - LC Filter Design (Rev. A)PDF, 1.6 Мб, Версия: A, Файл опубликован: 9 ноя 2016
- Class-D Amplifier External Load DiagnosticsPDF, 155 Кб, Файл опубликован: 23 янв 2017
This application report provides design information for an external load diagnostics circuit to detect andidentify electrical faults between the output of an audio amplifier and a target speaker. While theTPA3111D1-Q1 class-D amplifier is used as an example in this application note, this design methodologyis relevant for most class-D amplifiers to provide external fault diagnostics.
Серия: TPA3255 (3)
- TPA3255D2DDV TPA3255DDV TPA3255DDVR
- Semiconductors > Audio > High-Power Audio Amplifiers (>50W) > Analog Input Class-D
