Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TS3A5017RSV — Даташит
СерияTS3A5017
МодельTS3A5017RSV
Двойной аналоговый переключатель SP4T, 14 Ом Аналоговый мультиплексор/демультиплексор 3,3 В/2,5 В 16-UQFN от -40 до 85
TS3A5017 Dual SP4T Analog Switch / Multiplexer / Demultiplexer datasheet
PDF, 1.8 Мб, Версия: E, Файл опубликован: 29 апр 2015
Pin16
Package TypeRSV
Industry STD TermUQFN
JEDEC CodeR-PQFP-N
Width (мм)1.8
Length (мм)2.6
Thickness (мм).5
Pitch (мм).4
Max Height (мм).55
Additional FeaturesLow Harmonic Distortion
Low Power
Approx. Price (US$)0.28 | 1ku
Bandwidth(MHz)165
Bandwidth(Max)(MHz)165
Charge Injection(Max)(pC)5
Configuration1:4 SP4T
Crosstalk(dB)-74
Digital input leakage(Max)(uA)1
ESD Charged Device Model(kV)1
ESD HBM(kV)2
ICC(Max)(uA)10
Input/Ouput Voltage(Max)(V)3.6
Input/Output Continuous Current(Max)(mA)128
Input/Output OFF-state Capacitance(Typ)(pF)4.5
Input/Output ON-state Capacitance(Typ)(pF)24
Mux Configuration1:4
Number of Channels(#)2
OFF-state leakage current(Max)(ВµA)5
ON-state leakage current(Max)(ВµA)0.2
Off Isolation(Typ)(dB)-48
Operating Temperature Range(C)-40 to 85
Package GroupUQFN
Package Size: mm2:W x L (PKG)16UQFN: 5 mm2: 1.8 x 2.6(UQFN)
RON Flatness(Max)(Ohms)20
Ron Channel Match(Max)(Ω)3
Ron(Max)(Ohms)24
Ron(Typ)(Ohms)11
THD(Typ)(%)0.21
THD(Typ)(dB)-53.98
Turn off Time (Disable)(ns)6
Turn on Time (Enable)(Max)(ns)10.5
VCC(Max)(V)3.6
VCC(Min)(V)2.3
VIH(Min)(V)1.7
VIL(Max)(V)0.8
RoHSНе совместим
  • Preventing Excess Power Consumption on Analog Switches
    PDF, 238 Кб, Файл опубликован: 3 июл 2008
    Analog switches are extensively used for switching audio signals in battery-powered applications, such as mobile phones. In any cases, the switch is powered directly from the battery, but it receives control signals from a lower voltage processor GPIO. For most analog switches, this application condition leads to an excess supply current draw that catches system designers by surprise. This applica
  • Semiconductors > Switches and Multiplexers > Signal Switches > Analog Switch
На английском языке: Datasheet Texas Instruments TS3A5017RSV
